Go to Post Common sense can take you a long way!!! - ClintDog [more]
Unread 12-10-2016, 17:18
ruralrobotics ruralrobotics is offline
Rawhide Robotics
FRC #5657 (Rawhide Robotics)
Team Role: Coach
ruralrobotics will become famous soon enoughruralrobotics will become famous soon enough
Safety Button for Firing Cannon
We have built a four barrel pneumatic t-shirt cannon this year in robotics class that we need to program. We can build buttons for each solenoid to fire but really what we want to do is have a safety button assigned for each barrel. Example: While holding button six down and pulling the trigger on the joystick cannon one goes off. Then release button six and press button five down while pulling the trigger to shoot cannon two. This will prevent any accidental firing of the cannons by accidentally hitting a button. Can anyone screen shot us how to build something like this? Any help would be greatly appreciated.
Unread 12-10-2016, 19:31
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
Re: Safety Button for Firing Cannon
Just to clarify - all you want is to have to hit and hold two buttons down in order to fire - and in this case it would be the trigger?
There's lots of ways to implement this, but I would recommend this a structure like this:
Code:
if (trigger == 1):
   if (button1 == 1): fire cannon 1
   if (button2 == 1): fire cannon 2
else
{ //do nothing }
Basically you just want a nested case (https://decibel.ni.com/content/docs/DOC-3507) Your top level case will be if the safety button (your trigger in your example) is selected, and your inner case will just be the logic for the joystick buttons to fire a cannon.
Note: I realize this is the labview forum and I gave written code example, but I don't have labview on this computer. If this doesn't help and no one else chimes in, I'll see if I can find a computer that has it installed to build up real quick.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 14-10-2016, 15:50
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
I think this is what you're looking for.
This code will only allow one solenoid to fire and both the fire and the cannon enable button must be pressed.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 17-10-2016, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
Regardless of which barrel is firing, don't be standing in front of ANY of them...
