Go to Post I still believe that if we are legitimately trying to make FRC be recognized as a real sport, then the GDC must treat it like one. - Jim Zondag [more]
Unread 14-10-2016, 19:34
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Rookie Year: 2013
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Dead Radio
We were just prepping our robot for an outreach event at our school, when we realized that the radio seems to be dead. We have the power wired correctly, and used it all of last season with no issues, but now none of the lights are turning on. What should we do to diagnose the radio for problems, and how can they be fixed?
Unread 14-10-2016, 19:38
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Dead Radio
First thing I would do would be to take a multimeter and some spare wire and check to make sure you're actually getting 12V/2A out of your VRM. If you're not getting anything, you found your problem. Otherwise, put your black multimeter lead on the pin inside the barrel connector, and your red one on the outside. (You might get a negative number. I forget which is ground ). If you get nothing here, but you got something from the VRM, your problem is the cable. After that, if all of this works and your radio still doesn't get power, your radio is probably dead.
Unread 14-10-2016, 20:46
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Dead Radio
Center positive is common, meaning the center of the barrel plug is positive and the shell/outside is negative/ground. Make sure not to short it with the multimeter.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 20-10-2016, 13:55
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Dead Radio
Check that your VRM is getting power.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-10-2016, 17:39
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Re: Dead Radio
An often overlooked fault is the fuses for the RoboRio and VRM power rails, Ive had instances where one was knocked loose, so it looked fine, but once I touched it it was obvious, this is only an issue if you have no power going into the VRM of course
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
Unread 20-10-2016, 19:00
AKA: Alex Colello
Rookie Year: 2013
Re: Dead Radio
The VRM had power, it's status lights were green. I will check the cable tomorrow at our meeting.
