Go to Post When in doubt, ask... don't assume (unless you don't mind wasting time/money). - Bill Gold [more]
Unread 14-10-2016, 19:47
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Position and velocity PIDControllers using same encoder
Is there any supported way to do this in wpilib? It seems you have to set an encoder to be either kRate or kPosition - what if you want it to be one for one controller, and another for a different one? I suppose you could write a wrapper class that implements PIDSource and contains the encoder, but that seems ugly.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 14-10-2016, 20:01
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Re: Position and velocity PIDControllers using same encoder
Looking at the code, I think this is your only option. If I had a dime for every time I had to implement an ugly solution, I'd have like, three dollars.
Alternately, use Python, and pass in the function you want as the PIDSource.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 14-10-2016, 21:02
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Are you permitted to wire the encoder to two separate pairs of inputs... one to decode rate and one to decode position?
Unread 14-10-2016, 21:05
AKA: Eli Barnett
Can't see why not, unless this somehow counts as a custom circuit (I doubt it).
Not sure whether this or the in-code wrapper is clunkier. Perhaps this is something wpilib could support in the future.
Unread 14-10-2016, 21:13
Ether's Avatar
Rookie Year: 1969
Do you want the FPGA to compute your instantaneous rate and position? Does the wrapper approach accomplish that?
Unread 14-10-2016, 21:16
AKA: Eli Barnett
Wrapper should accomplish this, as encoder does have both a getPosition and getRate method - it's just that you can only set it to have PIDGet() call one of them or the other.
Unread 14-10-2016, 21:41
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
In your code where you set a set point on your velocity PID Controller couldn't you set the encoder to kRate mode and then in the code where you set a set point on your position PID Controller couldn't you set the encoder to kDistance mode? Unless I'm misunderstanding the use case you aren't going to be running both the position and the velocity PID Controllers at the same time so this should work.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 14-10-2016, 21:42
Captain
AKA: Nick Schatz
Rookie Year: 2014
I haven't tested this, and haven't read the implementation, but you may also be able to create two encoder objects, one for position and one for rate.
Clarify: with the same port numbers.
Second edit: out of curiosity, what's your use case for this?
Unread 14-10-2016, 21:46
AKA: Eli Barnett
I considered constructing two encoders on the same pins, but I strongly suspect this will throw an error. Will have to check.
The use case is controlling a turret - we're wondering if it's possible to do a cascading loop using the same encoder for both the external (position) loop and the internal (velocity) loop. It's probably totally unnecessary to do this (simple fixes for dealing with friction and whatnot work fine), but it's an interesting thought.
Unread 14-10-2016, 21:57
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Creating 2 encoder objects on the same pins technically would be allowed, as long as you used the DigitalSource constructors for the encoder, rather then the int constructor, and passed in preconstructed DigitalInput objects. However, this is overkill, as you can pass the same instance of an encoder to 2 separate PIDController objects. This would be my recommended way, as constructing 2 separate encoder objects actually takes away an encoder you could use for another purpose, whereas 2 PIDController objects with the same encoder object wouldn't take any extra resources.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 14-10-2016, 22:48
AKA: Eli Barnett
Yeah, but you can't send the same encoder object to two separate PIDController objects and have it be a kRate source for one of them and kPosition source for another. Hence the wrapper idea, which is ugly but would probably work.
Unread 15-10-2016, 00:29
Rookie Year: 2010
Oh I guess thats true. A small wrapper class would allow that however, and that class should be pretty thin.
Unread 26-12-2016, 16:54
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Here's a wrapper that 2485 wrote that does this.
https://github.com/team2485/frc-2016...dDistance.java
Unread 15-10-2016, 03:23
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
Rookie Year: 2012
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
If I understand your mechanism correctly, you are using both PID controllers to drive the same plant. One handles the position state while the second handles the velocity state. Velocity and acceleration feedforwards may help here. If you know what control signal you need to assert to produce a given velocity and acceleration, you could pass that information via feedforwards to a single position PID controller and remove the velocity PID controller. Otherwise, you could pass them to the inner velocity PID controller, and the velocity PID controller would, in effect, be accounting for uncertainties in your model that generates the velocity feedforward.
A custom controller that accounts for all three states (position, velocity, and acceleration) in the setpoint would be cleaner in my opinion, and the appropriate modifications to the PIDController class shouldn't be too difficult. By the way, state space controllers do this as well, but they require a reasonably accurate system model while PID does not.
  #15   Spotlight this post!
Unread 15-10-2016, 11:01
AKA: Eli Barnett
This is the idea. As I said, it's probably completely unnecessary - but I didn't see any reason why it couldn't be done, and thought it might be worth playing with.
