GRIP Deploy Not Working
Hello everyone,
My team is trying to use GRIP on our Raspberry Pi 3 to run the vision code for our robot. Each time we deploy, we keep recieving an error that I have pasted at the bottom of this post. We've followed all of the steps at https://github.com/WPIRoboticsProjec...Raspberry-Pi-2 and have copied over the shared libraries. Each time we deploy, it keeps saying that it can't instantiate files related to network tables. I'm sure that we have placed the shared libraries in the right folders and have deployed the project to the right folder, so do you know why this isn't working? I'm using GRIP 1.2 on Raspbian. Thanks, Jonathan Code:
/usr//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/pi/code/grip/grip.jar' '/home/pi/code/grip/project.grip'
Loading Dependency Injection Framework
Oct 15, 2016 3:58:43 PM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.2.0-5-g3a658db
platform: /Linux/arm/
Oct 15, 2016 3:58:45 PM edu.wpi.grip.core.GRIPCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[main,5,main]
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
at edu.wpi.grip.core.operations.networktables.NTManager.<init>(Unknown Source)
at edu.wpi.grip.core.operations.networktables.NTManager.class(Unknown Source)
while locating edu.wpi.grip.core.operations.networktables.NTManager
for field at edu.wpi.grip.core.Pipeline.ntManager(Unknown Source)
at edu.wpi.grip.core.Pipeline.class(Unknown Source)
while locating edu.wpi.grip.core.Pipeline
for field at edu.wpi.grip.core.serialization.Project.pipeline(Unknown Source)
at edu.wpi.grip.core.serialization.Project.class(Unknown Source)
while locating edu.wpi.grip.core.serialization.Project
for field at edu.wpi.grip.core.Main.project(Unknown Source)
while locating edu.wpi.grip.core.Main
Caused by: java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1864)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:57)
at edu.wpi.grip.core.operations.networktables.NTManager.<init>(NTManager.java:50)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:86)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:105)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:267)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1103)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:145)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41)
at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:54)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:132)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1016)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1012)
at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1051)
at edu.wpi.grip.core.Main.main(Main.java:43)
2) Error injecting constructor, java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
for field at edu.wpi.grip.core.serialization.StepConverter.pipeline(Unknown Source)
while locating edu.wpi.grip.core.serialization.StepConverter
for parameter 0 at edu.wpi.grip.core.serialization.Project.initialize(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:84)
3) Error injecting constructor, java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
for field at edu.wpi.grip.core.serialization.SocketConverter.pipeline(Unknown Source)
while locating edu.wpi.grip.core.serialization.SocketConverter
for parameter 2 at edu.wpi.grip.core.serialization.Project.initialize(Unknown Source)
3 errors
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1025)
Re: GRIP Deploy Not Working
I had this issue too. The Deploy page won't properly run GRIP, you have to use a custom script to do it. On this page it has this command:
Code:
$ env LD_LIBRARY_PATH=/home/pi/vision/grip:$LD_LIBRARY_PATH java -jar /home/pi/vision/grip/grip.jar /home/pi/vision/grip/project.grip |
I tried that but now it can't create a JVM. I'm just going to run GRIP on the driver station and stream the camera through the RIO USB port. Maybe we can get openCV running on the Pi next season. Is there a guide you followed for getting it to work with Network Tables?
You need to set the "LD_LIBRARY_PATH" environment variable to have the directory you put the ntcore libraries. You can do this either by the method on the wiki:
Code:
$ env LD_LIBRARY_PATH=/home/pi/vision/grip:$LD_LIBRARY_PATH java -jar ... Code:
export LD_LIBRARY_PATH=/home/pi/vision/grip:$LD_LIBRARY_PATH |
I think we missed this line in the wiki guide: "From the deploy window, click deploy. Once it's finished deploying just hit stop as GRIP will fail to run properly due to library issues." We're supposed to get the errors when we deploy, its normal, we should ignore it, and continue down the wiki where we run GRIP from the command line using the "env". I understand this is an RTFM error on mine and others' parts, but it might eliminate some questions if this was highlighted a bit more in the wiki. Correct? Well, I did that, and from the command line I'm getting: Code:
terminate called after throwing an instance of 'std::logic_error' what(): basic_string::_S_construct null not valid |
Yeah, the wiki could be better.
Can you post the full stacktrace? |
Pardon my ignorance but Linux is not my first language, where can I find the full stacktrace?
It's the entire output you got when you tried to run it from the command line, not just that one line. There should be a lot of lines that look like
"at edu.wpi.grip....(123)" |
#10
That's not a Java stack trace (it appears to be something in libstdc++), so I doubt there's anything else. I would recommend double-checking and making sure the correct libstdc++ is in the same folder you have in LD_LIBRARY_PATH, but I'm not really familiar enough with GRIP, so I can't offer much more than that.
#11
I definitely have the files linked to on the wiki there. Only difference is that I ftp'd them there and not scp. The only reason I can think that might make a difference is if the file permissions don't set the same. |
#12
I did alter the start_vision.sh from the wiki to include a -b to run in the background. Without it, I found the mjpg_streamer sat there and grip never started. Any help would be appreciated. Combined Vision Starting Script Start mjpg streamer enabling daemon modeforked to background (776) /home/pi/vision/start_vision.sh: line 5: pause: command not found Starting GRIP processing pi@pulsatrix:~ $ Nov 19, 2016 6:28:58 PM java.util.logging.LogManager$RootLogger log CONFIG: Configuration done. Nov 19, 2016 6:28:58 PM java.util.logging.LogManager$RootLogger log CONFIG: GRIP Version: 1.5.0-rc3 2016-11-19 18:29:02.026:INFO::main: Logging initialized @3761ms platform: /Linux/arm/ terminate called after throwing an instance of 'std::logic_error' what(): basic_string::_S_construct null not valid Edit: Seeing the pause error, I changed that line to read-p "--" and just counted to 5 before continuing. Same result. Edit2: pulsatrix is the name of the pi. Its the species name of the spectacled owl Last edited by kmckay : 21-11-2016 at 19:54. |
#13
That's bizarre. I'll see if I can reproduce this tonight. If not, you can use 1.5 and generate OpenCV code to run on the Pi without needing to deploy GRIP
#14
Just to be clear, this is the ssh window, not the grip deploy log.
#15
Code:
/usr/bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/pi/vision/grip/grip.jar' '/home/pi/vision/grip/project.grip'
Nov 19, 2016 3:38:27 PM java.util.logging.LogManager$RootLogger log
2016-11-19 15:38:30.111:INFO::main: Logging initialized @3056ms
Nov 19, 2016 3:38:32 PM edu.wpi.grip.core.GripCoreModule onThreadException
at edu.wpi.grip.core.operations.network.networktables.NTManager.<init>(Unknown Source)
at edu.wpi.grip.core.operations.network.networktables.NTManager.class(Unknown Source)
while locating edu.wpi.grip.core.operations.network.networktables.NTManager
while locating edu.wpi.grip.core.operations.network.MapNetworkPublisherFactory annotated with @com.google.inject.name.Named(value=ntManager)
for the 2nd parameter of edu.wpi.grip.core.operations.Operations.<init>(Unknown Source)
at edu.wpi.grip.core.operations.Operations.class(Unknown Source)
while locating edu.wpi.grip.core.operations.Operations
for field at edu.wpi.grip.core.Main.operations(Unknown Source)
1 error
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1028)
at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1054)
at edu.wpi.grip.core.Main.main(Main.java:52)
at edu.wpi.grip.core.operations.network.networktables.NTManager.<init>(NTManager.java:78)
at com.google.inject.internal.DefaultConstructionProxyFactory$ReflectiveProxy.newInstance(DefaultConstructionProxyFactory.java:126)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:194)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:56)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:110)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:120)
at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1019)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085)
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1015)
... 2 more
I have also attached the GRIP log. I'm 90% sure this is the newly generated file from last night running from command line, but I just realized the date is wonky on my pi so I am not 100% sure. (file format changed to txt for cd post) |
