Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 16-10-2016, 11:58
Sk84d2 Sk84d2 is offline
FRC #4592
Sk84d2 is an unknown quantity at this point
Java help
I am part of team 4592 and I took on the task of being programming captain. I don't know much and i need some help. I need to run a motor while a button is being pressed and held. I've gone through wpilib and can't figure it out. Thanks to anyone who can help it is greatly appreciated.
Unread 16-10-2016, 13:42
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Java help
WPILib resources:
Screensteps
API Reference (Java)
API Reference (C++)
Using the command based architecture, you need to first create a subsystem that the motor belongs to
Code:
public class MyMotorSubsystem extends Subsystem {
  CANSomething myMotor;
  public MyMotorSubsystem {
    myMotor = new CANSomething(RobotMap.CAN_ID_MY_MOTOR);
  public void setMotor(double value) {
    myMotor.set(value);
Then you need a command to run the motor.
Code:
public class CommandBase extends Command {
  public static MyMotorSubsystem myMotorSubsystem;
  public static void init() {
    myMotorSubsystem = new MyMotorSubsystem();
public class RunMotorCommand extends CommandBase {
  JoystickButton runMotorButton;
  public RunMotorCommand(JoystickButton runMotorButton) {
    this.runMotorButton = runMotorButton;
    runMotorButton.whenPressed(this);
  void initialize() {
    requires(myMotorSubsystem);
  void run() {
    myMotorSubsystem->setMotor(1.0);
  void isFinished() {
    return runMotorButton.get();
  void end() {
    myMotorSubsystem->setMotor(0.0);
  void interrupted() {
Then you need to create an instance of the command
Code:
// somewhere in OI.java
new RunMotorCommand(new JoystickButton(myJoystick, something));
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 17-10-2016, 00:35
Lireal Lireal is online now
AKA: Alex Colello
FRC #2141 (Spartonics)
Rookie Year: 2013
Lireal is on a distinguished road
Re: Java help
Here is what the above would look like in Java:
Code:
  ControllerType myMotor;
  public MyMotorSubsystem () {
    myMotor = new ControllerType(RobotMap.ID_MY_MOTOR);
    myMotor.set(value);
Command to run the motor.
Code:
  void initialize() {
  void execute() {
    myMotorSubsystem.setMotor(1.0);
  boolean isFinished() {
    return !runMotorButton.get();
  void end() {
    myMotorSubsystem.setMotor(0.0);
Create an instance of the command
Code:
My team does not use the CommandBase, and we usually instantiate subsystems in the Robot.java file, so I am not 100% sure this is right, but the basic idea should be apparent. Basically, create a command that in the execute will call a method from a subsystem that sets the motor to the value you want, which is triggered by a button and will end when that button isn't pressed.
Unread 19-10-2016, 20:10
bankst's Avatar
bankst bankst is offline
FRC #0832 (OSCAR)
Rookie Year: 2012
bankst is an unknown quantity at this point
Re: Java help
2016 was our first year with Java too, and being the sole programmer, I kinda got thrown into the fire. Here's our code from 2016. Its mostly very simple command-based stuff, but if you have any questions you can PM me. Hope that helps!
