No Robot Code
When we try to deploy our robot code, it says "Build Successful". In the FRC Driver Station, however, says there is no robot code.
-Communication light is Red on the roborio and the driver station Code can be found: https://github.com/Team-5243/Basketb...e/master/robot Build Log: Buildfile: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build.xml Trying to override old definition of task classloader clean: [delete] Deleting directory C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build [delete] Deleting directory C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\dist compile: [mkdir] Created dir: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build [echo] [athena-compile] Compiling src with classpath=C:\Users\Robotics1/wpilib/java/current/lib/WPILib.jar:C:\Users\Robotics1/wpilib/java/current/lib/NetworkTables.jar: to build [javac] Compiling 7 source files to C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build jar: [echo] [athena-jar] Making jar dist/FRCUserProgram.jar. [mkdir] Created dir: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\dist [mkdir] Created dir: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build\jars [echo] [athena-jar] Copying jars from C:\Users\Robotics1/wpilib/java/current/lib/WPILib.jar:C:\Users\Robotics1/wpilib/java/current/lib/NetworkTables.jar: to build/jars. [copy] Copying 2 files to C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\build\jars [jar] Building jar: C:\Users\Robotics1\Documents\FRCRobotics\2015-16\BasketBall\dist\FRCUserProgram.jar get-target-ip: [echo] Trying Target: roboRIO-5243-FRC.local [echo] roboRIO found via mDNS dependencies: [echo] roboRIO image version validated [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only [sshexec] Connecting to roboRIO-5243-FRC.local:22 [sshexec] cmd : test -d /usr/local/frc/JRE deploy: [echo] [athena-deploy] Copying code over. [scp] Connecting to roboRIO-5243-FRC.local:22 [scp] done. [sshexec] Connecting to roboRIO-5243-FRC.local:22 [sshexec] cmd : killall -q netconsole-host || : [scp] Connecting to roboRIO-5243-FRC.local:22 [scp] done. [echo] [athena-deploy] Starting program. [sshexec] Connecting to roboRIO-5243-FRC.local:22 [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r; [sshexec] Connecting to roboRIO-5243-FRC.local:22 [sshexec] cmd : sync BUILD SUCCESSFUL Total time: 9 seconds Things we have tried: --Updating Roborio firmware --Tried with multiple roborios --Tried with last year's code (worked last year, also included more sensor code, no change) --Tried redeploying easily 10 times After reading Ozrien's post in https://www.chiefdelphi.com/forums/s...hreadid=141652 --we tried to put a joystick in our last port (and in both ports). Did nothing. |
Re: No Robot Code
Have you tried looking for any messages that appear when attempting to run the code manually over ssh?
Re: No Robot Code
Just checking given all the things you did list that you've tried...
If you reimaged the RoboRIO, did you reinstall the Java Runtime on the RoboRIO? |
Re: No Robot Code
I also had this happen to me. Here is a link to the thread.
One thing I found(I believe it works) is to start over with the code. Deploy a basic FRC WPILIB example and to add one piece at a time and find where the code errors out. |
Re: No Robot Code
Looks like eclipse is able to connect but not the driver station. Double check that your team number is correct in eclipse preferences > WPILib (if not, fix it and redeploy) and that the team number is also correct on the driver station.
Re: No Robot Code
Are you sure you are running to code in github? There are 9 source files in github, but your build log only shows 7.
Re: No Robot Code
Found the issue.
The Shoot command activates the solenoid subsystem, waits 5 seconds, and then deactivates it. The issue? We put private SolenoidSubsystem SS = new SolenoidSubsystem(); as the attribute, instead of leaving it private SolenoidSubsystem SS; and then initializing it in the initialize method. |
Re: No Robot Code
