Go to Post So... the question is this: Does Grady keep his stuffed animals on his Barbie House for playtime, or in his bed to help him go sleepy-pie at night-night time? - Andy Baker [more]
Unread 10-23-2016, 11:19 PM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
pic: CGX-115, cam-counterweighted cycloidal drive
Unread 10-23-2016, 11:24 PM
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
Re: pic: CGX-115, cam-counterweighted cycloidal drive
As I understand this mechanism, the cyclodial gear nearest the cim drives against the mounting plate of the cim, which would be fixed against the main structure of the bot. The other cyclodial gear is driving against another plate which is mounted to the arm.
Because both cyclodial gears advance in the same direction, wouldn't this gearbox just provide a powered zero output?
BTW, great work, it's actually because of you that I know that these gearboxes exist at all.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 10-23-2016, 11:32 PM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
That's an interesting way to look at it. You would be correct if both cycloidal gears had the same tooth count. However, because the second stage gear is actually minus one tooth, the result is a little different.
This is the order of motion:
1. The miniCIM drives the camshaft
2. The wobble gear rotates around the CIM axis, but it itself turns once for every 30 rotations (the first 30:1 reduction)
3. The second wobble gear, bolted to the first one, rotates once for every 30 rotations as well.
4. Due to the eccentric nature of that rotation, the arm is pushed 1/30th of a rotation for each rotation of the second gear about its axis, creating the second 30:1 reduction.
It's a bit easier to see if you have the cad model working. The arm is forced to rotate, essentially.
Don't thank me, thank s_forbes! He provided the CAD model for the first cycloidal gears and the spreadsheet to calculate the gear ratio and dimensions.
<Now accepting CAD requests and commissions>
Unread 10-23-2016, 11:51 PM
FRC #0865
Rookie Year: 2010
That's really clever. I had the cad open on the grabcad site but the explosion was clear enough to get me to (mostly) figure out what was going on.
Just clarifying; because of the difference in gearing between the two cyclodial gears this goes from a powered zero to moving the difference between both "stages" every revolution.
The gear ratio should be the same as if this were a standard 2 stage cyclodial gearbox with the same number of teeth, as I understand it.
Unread 10-24-2016, 12:08 AM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
100% right.
Unread 10-24-2016, 12:19 AM
FRC #0865
Rookie Year: 2010
Wouldn't it be a 28*29:1 = 812:1 gearbox then? The output 'stage' has 30 pins therefore 29 lobes and the input has one less lobe.
Unread 10-24-2016, 12:32 AM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
If it was a normal reduction, yes. But in this case some witchcraft happens where the reduction on the second stage is just "# of pins on the ring gear" instead of "pins-1". I'm not exactly sure why, but I suspect it has to do with the way a planetary gearbox ring gear is exactly 1 less in the gear ratio, only in reverse. After all, in this case we are driving the ring and not the carrier.
Unread 10-24-2016, 04:14 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I'm a bit confused, this picture shows a big old mounting flange, but others show the versaplanetary mounting pattern. Did you draw both? I ask because we used 3 stage versaplanetaries this year at 250:1 reduction. We found we were really pushing it with the strength of the hex shaft, and especially the holding power of the two #10 screws. If you've got such a big reduction, consider engineering it to use another output and mounting arrangement to bolt directly to frame members and/or sprocket bolt circles.
Unread 10-24-2016, 04:57 PM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
There are two separate designs. This one is a larger, higher reduction gearbox meant for moving large arms at a 900:1 ratio off a miniCIM or CIM. The other one (CGX-116) is a VP stage with a lower reduction of 594:1, but can only output to a hex shaft.
I'm seriously considering designing a better VP output stage or output shaft that can hold a larger shaft and maybe output to a 1.875" hole pattern. I totally agree that the mounting options and hex shaft are limiting factors here.
Unread 10-26-2016, 01:31 PM
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
For anyone struggling to visualize this (as much as I hate to refer someone to Wikipedia) There's a good animation here.
https://en.wikipedia.org/wiki/Cycloi...idal_drive.gif
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 10-26-2016, 01:41 PM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
So apparently the radial loads on the camshaft (which is attached to the CIM shaft in this case) is equal to Torque/(eccentricity * gear ratio), which assuming you want to have a 200ft-lb (2400 lb-in) torque on this maximum comes out to
2400/(0.05*900)
or about 53 pounds of pure radial force on the CIM. A CIM at stall on a 12t pinion experiences about 22lbs of pure radial force. At the moment I have a pair of 8mm bearings in the output shaft, so it's probably safe, although on smaller gearboxes like the Versaplanetary version where this is not the case there could be savage failure modes. This is mainly a problem for cam-counterweighted cycloidal drives, as they don't have 2 wobble gears on 180* phase offsets to cancel out the forces.
Unread 10-26-2016, 02:05 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
This all looks great! A few quick things before I dive back into your CAD:
You're missing a few parts in your GrabCad folder for this assembly, like the small bearings around the first wobble gear, or the countersunk screws bolting the two wobble gears, and just a few small parts here and there.
Also, where did you get the 50mm ID 65mm OD bearings? Just wondering what supplier sells those.
And how did you determine the dimensions for the lightening pocket on the camshaft?
"It's taking longer than expected, which was to be expected."
Unread 10-26-2016, 02:41 PM
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
As usual, I forgot to do a Pack and Go. Try downloading the STEP file (GrabCAD has an option for that). Alternateively if you download the massive Parts folder it's all in there.
Recently I discovered the 6700 series bearings, and less recently the 6800 series bearings. These are very thin-section bearings, with the 6700 series being a mere 4mm wide and usually having a difference in OD between 6-7mm, so you can get a 30x37mm bearing. These are crazy useful for a lot of designs, and cost just a few dollars on Ebay or Aliexpress, as they are standard sizes. I believe I am using 6810 bearings in this design. There's an amazon supplier for 6800 series bearings that offers Prime, but they are vastly overpriced and usually cost $10-50 each compared to $1-5 for Aliexpress.
To get the lightening pocket just right, I first drew the maximum size pocket on the camshaft, in this case somewhere around a 0.09" outer wall and 0.125" thick material between the front and back pockets. I then made an assembly consisting only of the cam and the off-center rotating components including all the the gears, screws, and bearings. I mated the center of the cam to the origin and took Mass Properties readings to determine the center of mass, and trial-and-error adjusted the depth/wall thickness of the pocket accordingly. In this case, I ended up with a 0.09" wall and a 0.187" wall between the two pockets, and under 0.0001" of theoretical concentricity.
