Go to Post Go figure that by teaching you end up learning a lot through the process. ;) - Josh Fox [more]
Unread 10-25-2016, 08:23 PM
Calasada Calasada is offline
FRC #2783
Calasada is an unknown quantity at this point
Efficient Swerve Drive
Our team has been testing out swerve drive off-season (possibly) for next year. We have code that can successfully drive smoothly, but there are a few kinks we still need to work out to make it even more smooth. One of those that we are currently having trouble on is making the wheels drive backwards when we move backwards to spin the module in the most efficient way possible. We have tried a few rudimentary solutions that have failed miserably. Our modules are the AndyMark Swerve & Steer modules. Practically all of our swerve code is contained in the subsystem, pasted below. The "swerveDrive" method is used to take 3 values from the controller and output 8, 4 for steering and 4 for wheel speeds. Any help would be appreciated!
Code:
public class SwerveDriveBase extends Subsystem {
	private CANTalon frontRightWheel;
	private VictorSP frontRightSwivel;
	private CANTalon frontLeftWheel;
	private VictorSP frontLeftSwivel;
	private CANTalon rearRightWheel;
	private VictorSP rearRightSwivel;
	private CANTalon rearLeftWheel;
	private VictorSP rearLeftSwivel;
	private AHRS navSensor;
	private Encoder frontRightEnc;
	private Encoder frontLeftEnc;
	private Encoder rearRightEnc;
	private Encoder rearLeftEnc;
	private PIDController frontRightPID;
	private PIDController frontLeftPID;
	private PIDController rearRightPID;
	private PIDController rearLeftPID;
	private final double p = 0.05;    //0.015;
	private final double i = 0.0025;    //0.005;
	private final double d = 0.005;    //0.125;
	//TODO: Adjust value during testing. Some of this code is copied from 2016 Season Code, this value will change
	final private double ENCODER_TICKS_FOR_ADJUSTER_TRAVEL = 875.0;
	public class PIDOutputClass implements PIDOutput {
		public VictorSP motor;
		public PIDOutputClass(VictorSP motor) {
			this.motor = motor;
		@Override
		public void pidWrite(double output) {
			motor.set(output);
    public SwerveDriveBase() {
    	super();
    	frontRightEnc = new Encoder(new DigitalInput(2), new DigitalInput(3));
        frontLeftEnc = new Encoder(new DigitalInput(0), new DigitalInput(1));
        rearRightEnc = new Encoder(new DigitalInput(6), new DigitalInput(7));
        rearLeftEnc = new Encoder(new DigitalInput(4), new DigitalInput(5));
        PIDOutputClass frontRightPIDOutput = new PIDOutputClass(new VictorSP(RobotMap.FRONT_RIGHT_SWIVEL));
        PIDOutputClass frontLeftPIDOutput = new PIDOutputClass(new VictorSP(RobotMap.FRONT_LEFT_SWIVEL));
        PIDOutputClass rearRightPIDOutput = new PIDOutputClass(new VictorSP(RobotMap.REAR_RIGHT_SWIVEL));
        PIDOutputClass rearLeftPIDOutput = new PIDOutputClass(new VictorSP(RobotMap.REAR_LEFT_SWIVEL));
    	//Intstantiating PID Controllers with p, i, d, Encoder, Victor
    	frontRightPID = new PIDController(p, i, d, frontRightEnc, frontRightPIDOutput);
    	frontLeftPID = new PIDController(p, i, d, frontLeftEnc, frontLeftPIDOutput);
    	rearRightPID = new PIDController(p, i, d, rearRightEnc, rearRightPIDOutput);
    	rearLeftPID = new PIDController(p, i, d, rearLeftEnc, rearLeftPIDOutput);
    	frontRightPID.setInputRange(-180, 180);
    	frontLeftPID.setInputRange(-180, 180);
    	rearRightPID.setInputRange(-180, 180);
    	rearLeftPID.setInputRange(-180, 180);
    	frontRightPID.setContinuous();
    	frontLeftPID.setContinuous();
    	rearRightPID.setContinuous();
    	rearLeftPID.setContinuous();
    	//Makes sure navX is on Robot, then instantiates it
    	try {
	         navSensor = new AHRS(SPI.Port.kMXP);
	     } catch (RuntimeException ex ) {
	         DriverStation.reportError("Error instantiating navX MXP:  " + ex.getMessage(), true);
    	frontRightWheel = new CANTalon(RobotMap.FRONT_RIGHT_WHEEL);
    	//frontRightSwivel = new VictorSP(RobotMap.FRONT_RIGHT_SWIVEL);
    	frontLeftWheel = new CANTalon(RobotMap.FRONT_LEFT_WHEEL);
    	//frontLeftSwivel = new VictorSP(RobotMap.FRONT_LEFT_SWIVEL);
    	rearRightWheel = new CANTalon(RobotMap.REAR_RIGHT_WHEEL);
    	//rearRightSwivel = new VictorSP(RobotMap.REAR_RIGHT_SWIVEL);
    	rearLeftWheel = new CANTalon(RobotMap.REAR_LEFT_WHEEL);
    	//rearLeftSwivel = new VictorSP(RobotMap.REAR_LEFT_SWIVEL);
    public void initDefaultCommand() {
        setDefaultCommand(new SwerveDrive());
    //Small, simple tank drive method
    public void tankDrive(double leftValue, double rightValue) {
    	if (DriverStation.getInstance().isFMSAttached() && DriverStation.getInstance().getMatchTime() < 4) {
    		setBrake(true);
    	} else {
    		setBrake(false);
    	frontRightWheel.set(rightValue);
    	rearRightWheel.set(rightValue);
    	frontLeftWheel.set(leftValue);
    	rearLeftWheel.set(leftValue);
    //Method for calculating and setting Speed and Angle of individual wheels given 3 movement inputs
    public void swerveDrive(double FBMotion, double RLMotion, double rotMotion) {
    	//Swerve Math Taken from: https://www.chiefdelphi.com/media/papers/2426
    	//FBMotion = (FBMotion*(Math.sin(getNavSensor().getAngle()))) + (RLMotion*(Math.cos(getNavSensor().getAngle())));
    	//RLMotion = -(FBMotion*(Math.cos(getNavSensor().getAngle()))) + (RLMotion*(Math.sin(getNavSensor().getAngle())));
    	double L = 1.0;
    	double W = 1.0;
    	double R = Math.sqrt((L*L) + (W*W));
    	double A = RLMotion - rotMotion*(L/R);
    	double B = RLMotion + rotMotion*(L/R);
    	double C = FBMotion - rotMotion*(W/R);
    	double D = FBMotion + rotMotion*(W/R);
    	double frontRightWheelSpeed = Math.sqrt((B*B) + (C*C));
    	double frontLeftWheelSpeed = Math.sqrt((B*B) + (D*D));
    	double rearLeftWheelSpeed = Math.sqrt((A*A) + (D*D));
    	double rearRightWheelSpeed = Math.sqrt((A*A) + (C*C));
    	double t = 180/Math.PI;
    	double frontRightAngle = Math.atan2(B, D)*t;
    	double frontLeftAngle = Math.atan2(B, C)*t;
    	double rearLeftAngle = Math.atan2(A, C)*t;
    	double rearRightAngle = Math.atan2(A, D)*t;
    	double max = frontRightWheelSpeed;
    	if(max < frontLeftWheelSpeed) {max = frontLeftWheelSpeed;}
    	if(max < rearLeftWheelSpeed) {max = rearLeftWheelSpeed;}
    	if(max < rearRightWheelSpeed) {max = rearRightWheelSpeed;}
    	//I'm so sorry Jake
    	if(max > 1) {
    		frontRightWheelSpeed /= max;
    		frontLeftWheelSpeed /= max;
    		rearLeftWheelSpeed /= max;
    		rearRightWheelSpeed /= max;
    	//Set Wheel Speeds
    	frontRightWheel.set(frontRightWheelSpeed);
    	frontLeftWheel.set(frontLeftWheelSpeed);
    	rearLeftWheel.set(rearLeftWheelSpeed);
    	rearRightWheel.set(rearRightWheelSpeed);
    	//Set Wheel Angles
    	setFrontRightAngle(frontRightAngle);
    	setFrontLeftAngle(frontLeftAngle);
    	setRearLeftAngle(rearLeftAngle);
    	setRearRightAngle(rearRightAngle);
    //Turn on/off brake mode
    public void setBrake(boolean brake) {
    	frontRightWheel.enableBrakeMode(brake);
    	frontLeftWheel.enableBrakeMode(brake);
    	rearRightWheel.enableBrakeMode(brake);
    	rearLeftWheel.enableBrakeMode(brake);
    //Returns navX sensor ?
    public AHRS getNavSensor() {
    	if (navSensor != null) {
    		return navSensor;
    	} else {
    		return null;
    //Methods taken from ShooterBase in 2016 Code to help calculate angle
    public Double getFrontRightEncPercent() {
    	return Math.abs(frontRightEnc.getDistance() / ENCODER_TICKS_FOR_ADJUSTER_TRAVEL);
    public Double getFrontLeftEncPercent() {
    	return Math.abs(frontLeftEnc.getDistance() / ENCODER_TICKS_FOR_ADJUSTER_TRAVEL);
    public Double getRearRightEncPercent() {
    	return Math.abs(rearRightEnc.getDistance() / ENCODER_TICKS_FOR_ADJUSTER_TRAVEL);
    public Double getRearLeftEncPercent() {
    	return Math.abs(rearLeftEnc.getDistance() / ENCODER_TICKS_FOR_ADJUSTER_TRAVEL);
    public double getFrontRightAngle(){
		if (frontRightEnc != null) {
			return (getFrontRightEncPercent());
		} else {
			return -1.0;
    public double getFrontLeftAngle(){
		if (frontLeftEnc != null) {
			return (getFrontLeftEncPercent());
		} else {
			return -1.0;
    public double getRearRightAngle(){
		if (rearRightEnc != null) {
			return (getRearRightEncPercent());
		} else {
			return -1.0;
    public double getRearLeftAngle(){
		if (rearLeftEnc != null) {
			return (getRearLeftEncPercent());
		} else {
			return -1.0;
    //Methods to set Angles of wheels, enables PID then sets its setpoint as the input
    public void setFrontRightAngle(double angle) {
    	frontRightPID.enable();
    	frontRightPID.setSetpoint(angle);
    	System.out.println("out angle: " + frontRightPID.getSetpoint());
    public void setFrontLeftAngle(double angle) {
    	frontLeftPID.enable();
    	frontLeftPID.setSetpoint(angle);
    	System.out.println(angle);
    public void setRearRightAngle(double angle) {
    	rearRightPID.enable();
    	rearRightPID.setSetpoint(angle);
    public void setRearLeftAngle(double angle) {
    	rearLeftPID.enable();
    	rearLeftPID.setSetpoint(angle);
    //General Methods for moving any motor
    public void frontRightDrive(double value) {
    	frontRightWheel.set(value);
    public void frontRightTwist(double value) {
    	frontRightSwivel.set(value);
    public void frontLeftDrive(double value) {
    	frontLeftWheel.set(value);
    public void frontLeftTwist(double value) {
    	frontLeftSwivel.set(value);
    public void rearRightDrive(double value) {
    	rearRightWheel.set(value);
    public void rearRightTwist(double value) {
    	rearRightSwivel.set(value);
    public void rearLeftDrive(double value) {
    	rearLeftWheel.set(value);
    public void rearLeftTwift(double value) {
    	rearLeftSwivel.set(value);
Unread 10-26-2016, 12:18 AM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Efficient Swerve Drive
The trick to a smooth swerve and optimal control is to limit rotating the module as much as possible. If you think about it you should never have to rotate a swerve module more than 90 deg for a given action. The exception is for a smooth change over time like a tornado maneuver where the robot is spinning while traveling in a given direction. At any rate from a single step perspective a 90 degree limit is key. If the desired angle is more than 90 degrees and less than 270 degrees than it is going to be optimal to command the module to the desired angle + 180 and then reverse your motor speed.
We have handled this in the past using the following code.
Code:
//C++
if (fabs(desiredAngle - currentAngle) > 90 && fabs(desiredAngle - currentAngle) < 270) {
    desiredAngle = ((int)desiredAngle + 180) % 360;
    speed = -speed;
Here is our entire SwerveModule implementation from 2015.
https://github.com/Frc2481/frc-2015/...erveModule.cpp
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 10-26-2016, 09:13 AM
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is online now
I'm not very good at giving prizes
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
Poseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to behold
What we did in 5817's swerve code last year is this:
1) Added a method that lets us feed the wheel a degree value rather than an encoder position value.
2) Let's pretend the wheel is at 30 degrees east of North. If you want to get to 180 degrees South, the code will check and see whether it is faster to go clockwise or counterclockwise to 180.
3) The code then adds 180 to the angle (which in this case will equal 0/360 degrees) and with the two prior values in mind, checks whether it is even faster to go clockwise or counterclockwise to the new angle.
4) Now you have four angles: regular clock and counterclockwise, and reversed clock and counterclockwise.
5) Compare the four values and see which is the shortest and command the wheel to go to that position.
6) If the direction you chose goes to the reversed position, multiply the wheel power output by -1.
Hopefully this helps, I can share the code itself if you would like.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
Unread 11-03-2016, 07:54 PM
frodobaggins05 frodobaggins05 is offline
FRC #2783
frodobaggins05 is an unknown quantity at this point
Thanks for your help Poseidon5817 We fixed
