Legality of purchasing Planetary Gearboxes from alternative sources.
Because it is the offseason and teams maybe wanting to stock up on COTS parts for the 2017 season. Is it legal to utilise Planetary Gearboxes that have been purchased from a supplier like aliexpress in order to save money( a saving of around 50% percent).
There are several different types available from a variety of suppliers, that are identical to the Andymark ones. The motors even have the exact same labelling, and part numbers as the Andymark PG’s. But with a wider variety of ratio options: https://www.aliexpress.com/store/pro...727631977.html https://www.aliexpress.com/item/45mm...d08ed0fb&tpp=1 https://www.aliexpress.com/item/45mm-diameter-DC-12V-60RPM-planetary-gear-motor-Reduction-ratio-99-6k-PG45775126000-99-6K-for/32658954651.html?spm=2114.12010108.1000013.2.3FS9a b&scm=1007.13339.33317.0&pvid=1d8f4403-ffec-435d-827e-874e2411aeed&tpp=1 (shows identical part number) Considering that the motors are identical is it legal to use the gearboxes without replacing the motor? Last edited by roboruler : 10-28-2016 at 09:39 PM. |
Re: Legality of purchasing Planetary Gearboxes from alternative sources.
Subject to change for 2017, of course. |
The motor model numbers do not appear to be legal by last year's rules, as the rules would have to list RS-775123000, etc, and they do not list those motors.
https://firstfrc.blob.core.windows.n...-manual-04.pdf page 20 |
Please note that even if the gearbox is perfectly legal mechanically, for you to use it on a competition bot, it must be purchased from a legal vendor. Section 4.1 (pages 3 and 4) sets forth criteria necessary for a company to qualify to be a legal vendor. Aliexpress.com may not qualify. In fact, I seriously doubt it.
Of course, it could be argued that none of the vendors we think of as FIRST vendors actually qualify per the written criteria. (Not going there in this post.) This section of the manual is probably one of the most ignored rules in FRC. They should just delete it. |
Teams should note that regardless of how much the team paid for the part, they must list the part in the BOM at the fair market value price that any team could pay for the amount of the part they used on the robot (unless the part is KoP, etc). As for these specific gearboxes - if you wanted to go this route, I would seek out some documentation from AndyMark specifying that these are identical to a specific AM part number. If the only difference really is the part number marking, I believe this would be considered an equivalent COTS part under Example 4 of the 2016 blue box on page 4. Quote:
The motor rules themselves are more complicated - if those motors don't have identical part numbers already printed on them, I wouldn't push your luck. I'd just use the gearboxes and attach a definitely legal motor to them. Last edited by Chris is me : 10-31-2016 at 09:36 AM. |
But really, unless your team is really desperate for those few extra dollars,...
For small growing teams we need to be responsible with our dollars... I have been part of three different teams each with challenges and attributes.. but all have been out classed by those with bigger bank rolls , that are more established... If one looks at the pits independently... there is a huge range of sponsorship... and tools available... It can be overwhelming for a small team to see all that one has when they have all the tools they own in one tool box carried in, while others are offloading like a rock show... Please help us to make it affordable by all... |
Honestly, I can understand teams complaining because a product from AM or Vex doesn't work due to a bad design or something (looking at you GEM gearboxes and CIM encoder widgets!) but I don't understand the complaints about cost. I've been involved with FRC since 2003 and FRC has never been cheaper than it is now for a team to be competitive. It seems like it is becoming common to see teams not use their resources properly and then blame some grand FRC supplier conspiracy. No one is colluding to make gearboxes more expensive for FRC teams. AndyMark, Vex, CTRE, and REV have significantly lowered the barriers to entry for FRC teams and are continuing to drive down the costs for those teams to be competitive. Are the parts expensive? Yes. Is FRC expensive? Yes. Do teams need to plan and budget accordingly? Yes. Does FIRST need to provide better resources for teams to plan with? Yeah, they probably do. Are cheaper gearboxes from China a solution? Maybe, but I doubt it. EDIT: AliExpress is definitely a legal vendor for these gearboxes and other parts but I don't know about the motors and highly doubt the motors are legal. Last edited by marshall : 11-07-2016 at 12:35 PM. |
I'll leave why it feels like it's getting more expensive to compete as an exercise. I have some theories but I think I'd like to see what others think. [1] My process sucked for this I used archive.org and found the product I was looking for. I'm fairly certain of that flat period from 2005 to 2010 but since IFI's website blocked web crawlers from accessing the 884 page in their robots.txt I don't have that information and can only interpolate. But I don't recall the prices changing drastically in that point. If Paul/JVN/etc have more correct information feel free to correct me. |
Honestly, average/maximum cost graphs are going to be mostly the same since it wasn't until 2010ish that another ESC was allowed and it was more expensive (and actually less effective for most teams) The only year that the cheapest option ISNT the IFI/VexPro Victor line (883/884/SP) is 2016 in which it is the Spark ESC and the Victor retains its 2015 cost. For reference - I have (if Lydia/RIT group ever ships it back) a box of about a dozen 883s from 2003, they have been abused by several robots over the years and are still mostly ticking (they fried 1.5 of them when they tried to run a giant Ampflow motor off of them and cooked the fets) There's a reason the IFI Victors were a staple in combat robotics for a LONG time. They take a beating and, until recently, there was barely anything comparable on the market. Edit - to respond to Chris below: I went to archive.org for the site you buy the ESCs from and clicked on the link and checked the price. Whatever it said is what I put there. Last edited by Andrew Schreiber : 11-07-2016 at 03:10 PM. |
#11
Until the introduction of the Talon SP, the cheapest legal ESCs have been the best ESCs in competition; the Jaguars were generally more expensive and also worse. |
#12
![]() We haven't had any other motor controller with baked in cable strain relief that I know of. |
#13
Where does Andymark get their PG sets from? They don't make them in house otherwise they wouldn't have had to wait for a shipment to come in when they were out of stock. A 25 day lead sounds awful familiar...
When you ask this question, I'd have to know if they were the same gearboxes, and my gut reaction is that they are identical and most like come from the same source. We aren't in a position this year where money is going to stop us from buying an extra gearbox or two, but why on Earth would I pay double for the same thing? The only noticeabe difference is the price and lead time. Anyone have one of these in hand to say otherwise? |
#15
You just answered your own question - let's assume they are identical. Can you plan your requirements 25 days out during build season? No? So what you'd really like is some locally sourced components. But since they now have to stock in the hopes of you ordering they've taken on risk, couple that with costs of warehousing and shipping it to you. Really you're paying AM to stock the part for you so you can have it in your greasy hands tomorrow instead of next month.
