Go to Post darn design trade-offs! the game design committee does this to us every year! - KenWittlief [more]
Unread 28-10-2016, 21:36
roboruler roboruler is offline
Rookie Year: 2010
roboruler is infamous around these partsroboruler is infamous around these parts
Legality of purchasing Planetary Gearboxes from alternative sources.
Because it is the offseason and teams maybe wanting to stock up on COTS parts for the 2017 season. Is it legal to utilise Planetary Gearboxes that have been purchased from a supplier like aliexpress in order to save money( a saving of around 50% percent).
There are several different types available from a variety of suppliers, that are identical to the Andymark ones. The motors even have the exact same labelling, and part numbers as the Andymark PG’s. But with a wider variety of ratio options:
https://www.aliexpress.com/store/pro...727631977.html
https://www.aliexpress.com/item/45mm...d08ed0fb&tpp=1
https://www.aliexpress.com/item/45mm-diameter-DC-12V-60RPM-planetary-gear-motor-Reduction-ratio-99-6k-PG45775126000-99-6K-for/32658954651.html?spm=2114.12010108.1000013.2.3FS9a b&scm=1007.13339.33317.0&pvid=1d8f4403-ffec-435d-827e-874e2411aeed&tpp=1 (shows identical part number)
Considering that the motors are identical is it legal to use the gearboxes without replacing the motor?
