Go to Post Hey Kid! Get off my lawn!!! - Joe Johnson [more]
Unread 31-10-2016, 11:28
RyZeRun RyZeRun is offline
FRC #4104
RyZeRun is an unknown quantity at this point
"Getting Started" Errors
I created a WPILib example file, "Getting Started". This is my code:
Code:
#include "WPILib.h"
class Robot: public IterativeRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick; // only joystick
	LiveWindow *lw;
	int autoLoopCounter;
public:
	Robot() :
		myRobot(0, 1),	// these must be initialized in the same order
		stick(0),		// as they are declared above.
		lw(LiveWindow::GetInstance()),
		autoLoopCounter(0)
		myRobot.SetExpiration(0.1);
private:
	void AutonomousInit()
		autoLoopCounter = 0;
	void AutonomousPeriodic()
		if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
			myRobot.Drive(-0.5, 0.0); 	// drive forwards half speed
			autoLoopCounter++;
			} else {
			myRobot.Drive(0.0, 0.0); 	// stop robot
	void TeleopInit()
	void TeleopPeriodic()
		myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
	void TestPeriodic()
		lw->Run();
START_ROBOT_CLASS(Robot)
I get five errors:
- Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH
- The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetPOV' In line 7
- The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawAxis' In line 7
- The type 'Joystick' must implement the inherited pure virtual method 'GenericHID::GetRawButton' In line 7
- The type 'RobotDrive' must implement the inherited pure virtual method 'MotorSafety::GetDescription' In line 6
Also, 'START_ROBOT_CLASS(Robot)' has a syntax error.
How can I fix these errors?
Unread 31-10-2016, 13:07
mdballard's Avatar
mdballard mdballard is offline
SW and Control Systems Mentor
AKA: Matthew Ballard
FRC #4329 (Lutheran Roboteers)
Rookie Year: 2014
mdballard is an unknown quantity at this point
Re: "Getting Started" Errors
Hi,
Hopefully this will help:
1) "Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH"
This indicates that the development environment is probably not setup. If you are going to use Visual Studio you may wish to look at this thread: https://www.chiefdelphi.com/forums/s...=visual+studio
If you are just starting out with C++, I would recommend starting with the setup instructions described here: https://wpilib.screenstepslive.com/s.../13810/c/57252
My guess is that the rest of the errors you are seeing are related to include paths that need to be set for the WPILIB include directories.
I'm at my day job right now, but I can add more detail when I get home this evening. Hopefully the information I gave you above can help get you started.
Matt
Unread 01-11-2016, 18:30
FRC #4104
Originally Posted by mdballard View Post
Hi,
Matt
I'm using Eclipse Mars 2, and have installed the toolchain, plugins, etc. Everything's all set up. I double-checked the C++ setup.
Unread 01-11-2016, 19:06
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Try closing Eclipse, deleting C:\Users\<You>\wpilib, then starting Eclipse again (wait for it to recreate the folder)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
