Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 21-11-2002, 16:39
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enoughttedrow will become famous soon enough
PID Control Loops
This may be useful to some. I wrote a program that will control 3 seperate loops using a PID algorithm while still having enough room left in RAM to run the rest of the robot. I have tested it using Rob's emulator program but not in a real bot.
This program could be used for a 3-Axis arm or maybe steering and a 2-Axis Arm. If you would like to use my code feel free. Please let me know of any bugs or fixes that you find.
Have fun,
Tim Tedrow
The ZIP file with the code is now in the White Paper section.
http://www.chiefdelphi.com/forums/papers.php?s=
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Serious Controller Ideas archiver 1999 28 23-06-2002 23:01
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
