Go to Post heh...do the math! - MrForbes [more]
Unread 01-11-2016, 17:50
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
Would this Encoder work? and Encoder Recommendations
My team is looking to use encoders this year and I know a shaft encoder would work well so you could tap a hole in like hex shaft then just insert the encoder and it would work, but what encoders would people recommend? I've hard US Digital a lot. Would an encoder like this work, or would something else work better?
http://www.ebay.com/itm/NEW-US-DIGIT...AOSwfZ1WaMQ 7
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 01-11-2016, 17:58
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Would this Encoder work? and Encoder Recommendations
It would work. But how are you keeping it from losing contact with the hole in the hex shaft? Pressure fit? That would make it hard to swap out if needs service.
See if you can pressure fit a gear on to that shaft, and another on the hex shaft. Mount it gear-to-gear.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 01-11-2016, 18:07
Type's Avatar
Rookie Year: 2016
I didn't think of that. I've heard of people using part of surgical tubing I believe so it can turn, but a gear may work even better.
Unread 01-11-2016, 19:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We have also used shaft couplers to connect this sort of encoder to a drive shaft. If you are connecting a 1/4" stem to a 1/2" shaft, you will need a significant filler. A 5/16" nut takes a 1/2" wrench, so that'll get you most of the way there; a bit of tubing can do the rest.
Unread 02-11-2016, 09:20
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
We've used surgical tubing before and it works great. Drill and tap hole in the end of the shaft for a screw that comes relatively close to the diameter of the encoder shaft. The hole should be relatively centered but don't worry if it's off slightly. Cut the head off the screw, slap a jam nut of that sucker and Loctite it in place. Then attach the surgical tubing to both your screw and encoder and use zip-ties to clamp it on. You want to use as short a run of tubing as possible to eliminate any concerns for losing ticks to the torsion of the tubing, but you don't necessarily want the screw to butt up against the encoder shaft, since then concentricity DOES become a concern. Shoot for 1/4", maybe 1/2" gap.
This worked well for us. If you want to mount the encoder directly to the shaft, I have a suggestion for that too, but it will require me to break out my crappy paint skills. Just let me know if you're interested!
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 02-11-2016, 09:36
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
http://www.ebay.com/itm/160817272031...%3AMEBIDX%3AIT
Maybe worth a look for $10, much lower resolution though.
The sooner we get behind schedule, the more time we have to catch up.
Unread 02-11-2016, 09:48
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
That one Scott looks like a panel mount encoder intended as a human operated thumbwheel. Generally that means it isn't designed for use at speeds and stresses drive mechanisms see.
Unread 02-11-2016, 10:05
Type's Avatar
Rookie Year: 2016
I've heard of teams using like US digital s4t (if I remember correctly), where would you purchase one of these? I couldn't find any on Ebay...
Unread 02-11-2016, 11:57
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Either andymark or direct from US Digital. We placed an order direct a few years ago, we probably will this year as well (discount for bulk ordering). I'm still trying to find an alternative.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 02-11-2016, 12:14
Type's Avatar
Rookie Year: 2016
http://www.usdigital.com/products/s5
Sorry for so many questions, but would an encoder like this work? I noticed there were for sale here on CD by another team, the connectors just look a little different.
S5-5000-250-IE-S-B to be specific.
Unread 02-11-2016, 12:26
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
I purchased one of these the other day for a personal project.
I wanted 360 PPR, and relatively low cost, so this fit the bill.
When it arrived, I was STUNNED by the build quality!! It is a VERY well built encoder! That said, it is a lot larger than most encoders of this style. It is approx. 1.5" dia. and approx. 1.4" long. I also found that using 4.7K ohm pull up resistors with it made it very stable with my Arduino.
BTW, you can get this in a couple more PPR values.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 02-11-2016, 13:05
Type's Avatar
Rookie Year: 2016
So how does PPR affect the code when using a drive train? I've seen some that are rated for like 5k and others that top out at 360. Im assuming you would use one that hits 5k for a shooter, but would a 360 CPR (or PPR) be enough for a drive train to be accurate.
Unread 02-11-2016, 13:25
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Sorry, I was suggesting a lower cost option for testing, not a production encoder, should have been clear, in my eBay searching.
We use the S4T, they set you back $70 a pop, but are bullet proof. Order directly from US Digital at.
http://www.usdigital.com/products/en...tary/shaft/S4T
Unread 02-11-2016, 13:41
One Eyed Man
Rookie Year: 2010
On drive train, it depends on what you're doing. We use 250PPR and its still overkill. I think 1 pulse corresponds to 1mm of travel but that can change on if you are using the input or output to the gearbox.
For shooters, we've typically use 2PPR. When you've got a wheel spinning at a few thousand RPM, you don't need many counts per rev to get an accurate speed. A 5kPPR would amount to over 2 million pulses per second on some shooters we've used.
  #15   Spotlight this post!
Unread 02-11-2016, 13:42
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
"Bulletproof"? I have always found the S4 series to be pretty fragile, with some of them unexpectedly stopping function on a regular basis.
If you want a bulletproof encoder, you're better better off with a Grayhill or an AMT-103/102. Both of those I have seen take serious abuse without failures.
<Now accepting CAD requests and commissions>
