Go to Post Unfortunately, you cannot always tell when some things are jokes on forums, because we only can rely on text and a limited number of smilies. - artdutra04 [more]
Unread 12-11-2016, 08:42
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Team Role: Coach
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
[FTC]: [FTC]:785 servo programming
I have a 785 servo that i use for a ramp up/down scenario.
I used the Modern Robotics tool and found that my lower position is 81, divided by 255 and we end up with 0.31 and for raise position, we had 52, /255 = 0.20.
When i start the program i can do the setposition command and should get that to work... but when i turn on the power right now... the servo is trying to move to 128.....
that where i get confused.... thats before i start any program... so where would i set it to stop?
We are programming in java with android studio....
