Go to Post I have never gone to a FIRST Robotics competition and not had fun. - mathking [more]
Unread 12-11-2016, 13:06
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
Rookie Year: 2013
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Sending OpenCV Output back to the Driver Laptop?
Hi,
We have a mini-PC on our testing robot and we are testing some different vision code. One problem is that in our OpenCV Python code, we simply cannot figure how to send the final image back to us. We have looked all other the internet with no avail.
We would like to be able to the output for not only testing but eventually, we might make a driver assist computer vision program that points out game pieces and such.
Ideally, we would like to be able to send it to an HTTP page, but we are open to other options. Also, being low latency is a big need in the solution.
Thanks a bunch in advance!
#Python4Life
Unread 12-11-2016, 13:47
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Sending OpenCV Output back to the Driver Laptop?
Have you looked at mjpg-streamer?
https://github.com/robotpy/mjpg-streamer
Unread 12-11-2016, 15:16
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
You could reimplement the WPILib CameraServer protocol (which is pretty easy if you ignore the client to server side). Basically on a TCP connection on port 1735, repeatedly send the following in order:
- the bytes 1, 0, 0, 0
- a network-order 32-bit integer with the length in bytes of the frame data (JPEG format)
- the JPEG frame data
Then you can view the stream on SmartDashboard with the USB Camera widget.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 12-11-2016, 22:00
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
How could I input the output stream of OpenCV with MJPG Streamer?
#Python4Life
Unread 13-11-2016, 00:20
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
There's an OpenCV input plugin that you can use. https://github.com/robotpy/mjpg-stre...s/input_opencv
And, it supports a python input plugin. https://github.com/robotpy/mjpg-stre...r_py/README.md
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 13-11-2016, 13:06
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
This is exactly what I was looking for! However, I am clueless on how to add this plugin to my MJPG-streamer installation on my Linux PC.
#Python4Life
Unread 13-11-2016, 13:13
virtuald's Avatar
RobotPy Guy
If you have the right prerequistites installed (python-devel, numpy, and opencv-devel 3.1), then when you build mjpg-streamer using CMake it should just automatically detect the dependencies and build it.
Unread 13-11-2016, 19:18
AlexanderTheOK AlexanderTheOK is offline
Guy
Rookie Year: 2012
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
While I personally have used mjpg-streamer for some other projects, I've never used it to serve images from opencv. my preferred method has been this copy pasted and cut up to be used as it's own module. Might be interesting to see if there are any performance differences between doing it yourself and going through mjpg-streamer.
Unread 13-11-2016, 20:53
virtuald's Avatar
RobotPy Guy
The code you linked to is fairly inefficient in a couple of different ways (in particular, it doesn't reuse image buffers), so I'm sure out of the box the mjpg-streamer would beat the pants out of it, particularly if you ran it on a RoboRIO.
After optimization, I suspect the mjpg-streamer version would still end up winning.
