Go to Post So kudos for asking advice... you've got plenty of good advice so far in this column... but honestly, if Orville and Wilbur Wright had taken good advice they would have packed up and gone back to their bicycle shop. - dtengineering [more]
Unread 13-11-2016, 22:47
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
pic: Average Winch Innards
Unread 13-11-2016, 22:48
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: pic: Average Winch Innards
That's really neat, and a good way to compact the winch (the motor is inside the winch drum, instead of beside it). I'm still really wary of loading the CIM structurally, but more and more teams seem to be experimenting with the idea.
Unread 13-11-2016, 23:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I can't seem to make sense of the picture and the text at the same time.
Is that thing which looks like a 2.5" shaft collar really a rotating bearing?
Is the CIM mounted to the chassis, or is the end of the gearbox shaft?
If the shaft, do you have slip rings, or just enough slack to take up the number of turns the drum will make, and how do you support the other (CIM end) of the drum?
If the CIM, how is it mounted to the chassis which still allows the drum to turn?
Unread 13-11-2016, 23:41
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
I agree the photo and text aren't perfectly clear. Here's my understanding: The winch drum (not shown) surrounds the motor and gearbox, supported on the left by the black bushing (which fits snugly over the CIM), and on the right by the versaplanetary shaft. The whole thing mounts using the silver shaft collar and maybe? another bearing on the versaplanetary shaft?
A photo of the full assembly would be helpful
Unread 14-11-2016, 00:38
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Team Role: Mechanical
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I think you are correct. I like the idea, in concept, but in practice it seems like a heavy way gain a minimal amount of space.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 14-11-2016, 07:01
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Quite a few low bar bots had weight to spare and had space at a premium. We did something similar with our ball collector for aerial assist, made some good confusion faces happen when people tried to figure out how it worked. Wish I would have taken a closer look at this one this year.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 17-11-2016, 22:34
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
This is extremely true. I know of a number of bots that competed <100 lbs. Heck, Perses (the 'Snow Problem Ri3D) was around 70 without the battery. Probably the last time we'll see a game where space is at more of a premium than weight for a while.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 14-11-2016, 15:38
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Here are a few decent photos I took at Worlds.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 14-11-2016, 16:20
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Very clever! Might have to remember this if we need to winch anything this year.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 15-11-2016, 03:01
Jean Tenca's Avatar
Jean Tenca Jean Tenca is offline
Head Mentor
AKA: "John"
FRC #4488 (Shockwave)
Jean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of light
Very cool. I'm curious, is there anything special with the wiring for this? How do you accommodate the motor rotating so many times? I've seen a few robots do motors in rollers in the past, but I've always been unsure as to how exactly they wire them.
Team 4488 Head Mentor
2015: [Carson Division Finalists (World Championship)], [Finalists, Entrepreneurship Award (PNW District Championship)], [Winners, GP Award (CWU District)], [Winners, Engineering Excellence (Oregon City District)]
2014: [Galileo Division Finalists (World Championship)], [Finalists, Quality Award (PNW District Championship)], [Winners, Industrial Design (Wilsonville District)], [Winners, Chairman's (Oregon City District)]
2013: [Rookie All-Star (Curie Division)], [Highest Rookie Seed, Rookie All Star (Autodesk Oregon Regional)]
2006-2012: Mentored various teams in OR and WA
2005: Team 1510 captain, founding member
2002-2004: Team 955 student/captain, founding member
Unread 15-11-2016, 07:00
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Richard can correct me if I'm wrong, but from Mike's picture it looks like the CIM is mounted and the spool rotates around the CIM. Not shown in the original picture is a large gear that fits on the end of the VP and bolts to the side of the spool and spins it. If this is right, then there is no need to worry about the CIM wires rotating.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 15-11-2016, 07:55
NoshBrooks's Avatar
NoshBrooks NoshBrooks is offline
AKA: Noah Brooks
FRC #3620 (The Average Joes)
Team Role: Student
Rookie Year: 2016
NoshBrooks is an unknown quantity at this point
The Winch functioned as you all have guessed, although, we did end up using a half inch ratcheting wrench to prevent the system from reversing after endgame.
In all honesty we don't have the best climber, it was fairly slow and usually made more sense to just score 2 balls and take the tower. Nice to have it working though. We saw some other teams like 4967 do something similar to our method, not sure how well it worked, never got to see it in a match!
It was mounted on 2 brackets riveted to the belly-pan.
Unread 15-11-2016, 07:56
NoshBrooks's Avatar
AKA: Noah Brooks
Team Role: Student
Rookie Year: 2016
[quote=NoshBrooks;1616372]The Winch functioned as you all have guessed, although, we did end up using a half inch ratcheting wrench to prevent the system from reversing after endgame.
It was mounted on 2 brackets riveted to the belly-pan. The sheath spun around the sim and the sim was hard mounted to the frame.
Unread 17-11-2016, 13:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
o.O
The pictures of the full assembly are the closest to "magic" I have seen in FRC in a long time. Very cool design.
GitHub
  #15   Spotlight this post!
Unread 14-11-2016, 12:03
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Originally Posted by Richard Wallace View Post
Average job good sirs
11 Years and counting! Over a third of my life has been spent with FRC.
