Go to Post Swerve Drive (n.) - a set of mechanisms to ensure the robot will sit dead on the field for half of that robot's first event - Kevin Leonard [more]
Unread 11-14-2016, 05:27 PM
dgummadi dgummadi is offline
FRC #2472
dgummadi is an unknown quantity at this point
GRIP implementation into robot code
Our team is attempting to use GRIP to process vision, when we generate the code and implement it into our robot code eclipse has no errors with openCV however when the code is compiled the compiler prints this:
Code:
 [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:35: error: cannot find symbol
    [javac] 	private Mat source0;
    [javac] 	        ^
    [javac]   symbol:   class Mat
    [javac]   location: class Pipeline
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:73: error: cannot find symbol
    [javac] 	public void setsource0(Mat source0) {
    [javac] 	                       ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:81: error: cannot find symbol
    [javac] 	public Mat rgbThresholdOutput() {
    [javac] 	       ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:110: error: cannot find symbol
    [javac] 	private void rgbThreshold(Mat input, double[] red, double[] green, double[] blue,
    [javac] 	                          ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:111: error: cannot find symbol
    [javac] 		Mat out) {
    [javac] 		^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:140: error: cannot find symbol
    [javac] 	private void findLines(Mat input, ArrayList<Line> lineList) {
    [javac] 	                       ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:30: error: cannot find symbol
    [javac] 	private Mat rgbThresholdOutput = new Mat();
    [javac] 	                                     ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:37: error: cannot find symbol
    [javac] 		System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
    [javac] 		                   ^
    [javac]   symbol:   variable Core
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:51: error: cannot find symbol
    [javac] 		Mat rgbThresholdInput = source0;
    [javac] 		^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:58: error: cannot find symbol
    [javac] 		Mat findLinesInput = rgbThresholdOutput;
    [javac] 		^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:112: error: cannot find symbol
    [javac] 		Imgproc.cvtColor(input, out, Imgproc.COLOR_BGR2RGB);
    [javac] 		                             ^
    [javac]   symbol:   variable Imgproc
    [javac] 		^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:113: error: cannot find symbol
    [javac] 		Core.inRange(out, new Scalar(red[0], green[0], blue[0]),
    [javac] 		                      ^
    [javac]   symbol:   class Scalar
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:114: error: cannot find symbol
    [javac] 			new Scalar(red[1], green[1], blue[1]), out);
    [javac] 			    ^
    [javac] 		^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:141: error: cannot find symbol
    [javac] 		final LineSegmentDetector lsd = Imgproc.createLineSegmentDetector();
    [javac] 		      ^
    [javac]   symbol:   class LineSegmentDetector
    [javac] 		                                ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:142: error: cannot find symbol
    [javac] 		final Mat lines = new Mat();
    [javac] 		      ^
    [javac] 		                      ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:147: error: cannot find symbol
    [javac] 			final Mat tmp = new Mat();
    [javac] 			      ^
    [javac] 			                    ^
    [javac] C:\Users\2472\workspace\Something-Creative\src\src\Pipeline.java:148: error: cannot find symbol
    [javac] 			Imgproc.cvtColor(input, tmp, Imgproc.COLOR_BGR2GRAY);
    [javac] 			                             ^
    [javac] 			^
    [javac] 28 errors
BUILD FAILED
C:\Users\2472\wpilib\java\current\ant\build.xml:71: Compile failed; see the compiler error output for details.
Anyway, it appears to me that the Mat inside the openCV library is not in the build path. However when I check in Project>properties>Java Build Path it shows opencv-3.1.0 as one of the libraries.
Am I implementing GRIP incorrectly or is there a way to fix this issue?
Unread 11-14-2016, 08:43 PM
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: GRIP implementation into robot code
You need to add the OpenCV jar as a user library in build.properties, it won't work if you only add it as a normal Eclipse dependency.
The easiest way to do it is to put the jar in ${user.home}/wpilib/user/lib (for you, C:\Users\2472\wpilib\user\lib\opencv-java-3.1.0.jar) and add that jar as an Eclipse dependency
Your build.properties file should then have the line
Code:
userLibs=${user.home}/wpilib/user/lib/opencv-java-3.1.0.jar
Note that I'm referencing WPILib's build of OpenCV (which can be found here) which doesn't contain any compiled native libraries.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
