Go to Post With a little time and practice, I think that most people would find that there is no magic involved in programming. - Dave Scheck [more]
Unread 15-11-2016, 10:04
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
Rookie Year: 2012
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
What brand of pneumatics do you use?
In the past we have used SMC. However last your we had some problems at competition and it seemed nobody else used them. So i am just wondering what is popular among other teams.
EDIT: We did not have problems with the SMC parts themselves. We did not stock spare parts properly and when we broke one of the solenoids by striping out one of the screw we couldn't find any teams that had any spare parts at competition. The reason for this thread is to find what other teams are using so that we can use what other teams are using for better support at competition.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 15-11-2016, 11:15
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
Re: What brand of pneumatics do you use?
Personally I have never had much of an issue using Bimba products.
Unread 15-11-2016, 11:26
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Bimba/Pneumadyne.
Have not had any issues thus far.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 15-11-2016, 11:39
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
no team (MetalWorks)
Wren Hensgen will become famous soon enoughWren Hensgen will become famous soon enough
We used mainly Bimba for cylinders, because they're more readily available (produced stateside), and offer more customization options. You can configure a cylinder on their site, and have a CAD model ready to test instantly.
We used to use FESTO, but have swapped over to Humphrey for solenoids, as their balanced series switch faster, and have better flow in a smaller package.
For fittings, we had a mix of SMC/Parker, which were swapped over to Norgren (Norgren has the inside of the fitting hex broached, so you can tighten them with an allen wrench, a lifesaver in tight spaces)
Through FRC, I now work for a fluidics (Hydraulic and pneumatic) distributor. If you have any questions, or are looking for a certain part, I'd be happy to help
Unread 15-11-2016, 12:01
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
Rookie Year: 2013
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Plus, they donate a voucher for two free cylinders. Can't go wrong supporting a company that gives back!
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 15-11-2016, 12:03
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
We use cylinders from Automation Direct (forgot the exact brand) because they're cheaper than Bimba, who we used to use. We still use Bimba for CAD models and oddball sizes, but stick to AD for most everything else.
EDIT: Apparently they are NITRA brand.
<Now accepting CAD requests and commissions>
Unread 15-11-2016, 12:22
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
SMC, Festo, Automation Direct, at least one other which Andymark sells. Pretty much it depends on what we need in a given year.
What problems did you have?
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 15-11-2016, 12:34
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
I am surprised you had problems with SMC. They make good stuff. We use mostly Automation Direct. Nitra is their house brand not an actual MFR. AD has good customer service, good prices, and fast shipping (free for orders over $49).
If you don't know what you should hook up then you should read a data sheet
Unread 15-11-2016, 12:52
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
Rookie Year: 2012
Unread 15-11-2016, 13:07
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
We also use many Bimba products
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 16-11-2016, 07:34
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Team Role: Teacher
Rookie Year: 1999
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
We use Clippard pneumatics - exclusively. Extensive parts catalog, quick orders. Of course, they're one of our team sponsors and hire many of our students.
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 18-11-2016, 01:38
Nitay's Avatar
Nitay Nitay is offline
Moving FIRST Forward
AKA: Nitay Sheffer
FRC #1574 (MisCar)
Rookie Year: 2010
Nitay is an unknown quantity at this point
Clippard, Bimba and Baccara (a local manufacturer).
Nitay from MisCar 1574, Israel.
2005-2008, 2011, 2014, 2015 Regional Winner
2012 & 2015 Engineering Inspiration Award
2006, 2009, 2012, 2016 Woodie Flowers Award
miscar1574.org and on Facebook
Unread 18-11-2016, 01:42
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Bimba cylinders, Festo solenoids, Clippard tanks, McMaster tubing. Kinda just the standard stuff that comes in the kit, with the occasional order from McMaster or Bimba for custom stuff.
Fun fact, a few years back, one of our mentors ordered like a 3" bore 36" stroke cylinder to test the limits of what Bimba can make.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 18-11-2016, 07:26
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
If you're using really really standard sizes (e.g. recommended cylinder for a COTS shifter or butterfly module), you might find a spare, but even coming off the Bimba voucher, there are several dozen combinations of stroke and diameter, so it is unlikely that anyone will have a match on hand. if you're using a cylinder that isn't on the voucher or recommended for a COTS subsystem, it's a long shot in the dark. We build "twin" robots to have one for practice and tweaking, and if nothing else, we always bring the pneumatic cylinders from the practice robot, and usually the compressor, solenoid valves, and other COTS parts.
We use mostly Bimba as well; their online CAD generator is great! Even though we didn't CAD our launcher last year, we were able to use the CAD to build a model of the cylinder we used to stretch the springs, so we were able to build the rest of the launcher to fit. This was essential, as our cylinders last year did not arrive until after stop build. These were custom cylinders ordered around mid-build season.
