Go to Post I love math... :D - Eric W. Jones [more]
Unread 16-11-2016, 00:12
jkgjur jkgjur is offline
FTC #9830
jkgjur is an unknown quantity at this point
[FTC]: [FTC]: Using Android's Built in Sensors
I have been playing around with getting the built in sensors in the ZTE phones to return some values for me. Currently, I just want it to return the different sensors available on the phone. I have written code that will do this, but as soon as I initialized the robot, it gave off this error:
Code:
Can't create handler inside thread that has not called Looper.prepare()
I looked up the error and I tried using the methods that were given. I wrote some more code that could have possibly fixed it, but the same error was returned. This is the current code that I am testing:
My Sensors class
Code:
package org.firstinspires.ftc.robotcontroller.internal.sensor;
import android.app.Activity;
import android.hardware.SensorEventListener;
import android.hardware.SensorManager;
import android.hardware.Sensor;
import android.hardware.SensorEvent;
import android.os.Handler;
import android.os.Looper;
import java.util.List;
public class Sensors extends Activity implements SensorEventListener {
    private final SensorManager sensorManager;
    public Sensors() {
        sensorManager = (SensorManager)getSystemService(SENSOR_SERVICE);
    protected void onResume() {
        super.onResume();
    protected void onPause() {
        super.onPause();
        sensorManager.unregisterListener(this);
    public void onAccuracyChanged(Sensor sensor, int accuracy) {
    public void onSensorChanged(SensorEvent event) {
    public String listAvailableSensors() {
        List<Sensor> sensorList = sensorManager.getSensorList(Sensor.TYPE_ALL); // gets list of all sensors available on the phone
        return sensorList.toString();
My TestPhoneSensor class
Code:
import android.os.Message;
import com.qualcomm.robotcore.eventloop.opmode.OpMode;
public class TestPhoneSensor extends OpMode {
    Sensors sensor;
    @Override
    public void init() {
        sensor = new Sensors();
    @Override
    public void init_loop() {
    class LooperThread extends Thread { // code block that was supposed to "fix" it
        public Handler mHandler;
        public void run() {
            Looper.prepare();
            mHandler = new Handler() {
                public void handleMessage(Message msg) {
            Looper.loop();
    @Override
    public void loop() {
        new Thread() { // other code block that was supposed to "fix" it
            public void run() {
                new Sensors().runOnUiThread(new Runnable(){
                    @Override
                    public void run(){
                        try {
                            telemetry.addData("Sensor List:", sensor.listAvailableSensors());//Edit,integrate this on the runOnUiThread
                        } catch (Exception e) {
                            telemetry.addData("Error:", e.getStackTrace());
        }.start();
Any help is appreciated.
Unread 19-11-2016, 21:31
batteriesinblac batteriesinblac is offline
FTC #4855
batteriesinblac is an unknown quantity at this point
Post Re: [FTC]: [FTC]: Using Android's Built in Sensors
You want the code structured similar to the snippet below
Code:
	// get sensorManager and initialise sensor listeners
		mSensorManager = (SensorManager) hardwareMap.appContext.getSystemService(Context.SENSOR_SERVICE);
		if (mSensorManager.getDefaultSensor(Sensor.TYPE_ACCELEROMETER) == null ||
				mSensorManager.getDefaultSensor(Sensor.TYPE_GYROSCOPE) == null ||
				mSensorManager.getDefaultSensor(Sensor.TYPE_LINEAR_ACCELERATION) == null ||
				mSensorManager.getDefaultSensor(Sensor.TYPE_MAGNETIC_FIELD) == null) {
			DbgLog.msg("FTC4855 - For this OpMode a phone with Gyro / Accelerometer / Magnetometer is required");
			bInitialized = false;
		else {
			bInitialized = true;
			initListeners();
			// wait for one second until gyroscope and magnetometer/accelerometer
			// data is initialised then scedule the complementary filter task
			fuseTimer.scheduleAtFixedRate(new calculateFusedOrientationTask(),
					1000, TIME_CONSTANT);
	// This function registers sensor listeners for the accelerometer, magnetometer and gyroscope.
	private void initListeners(){
		mSensorManager.registerListener(this,
				mSensorManager.getDefaultSensor(Sensor.TYPE_ACCELEROMETER),
				SensorManager.SENSOR_DELAY_FASTEST);
				mSensorManager.getDefaultSensor(Sensor.TYPE_GYROSCOPE),
				mSensorManager.getDefaultSensor(Sensor.TYPE_MAGNETIC_FIELD),
				mSensorManager.getDefaultSensor(Sensor.TYPE_LINEAR_ACCELERATION),
