Go to Post I too can find a method with correlation bias by applying a pattern to most datasets! - BrennanB [more]
Unread 11-17-2016, 09:11 PM
ZoomZoom ZoomZoom is offline
FRC #3495
ZoomZoom is an unknown quantity at this point
Drivetrain Sprocket
I'm a freshman and I am doing a cad of a drivetrain. I'm doing a west coast 4 pneumatic 6 inch tires. I don't know what size sprocket or chain to use. I am designing this for the 2016 game
Sent from my iPhone using Tapatalk
Unread 11-17-2016, 09:23 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Drivetrain Sprocket
First question is, how much manufacturing slop are you likely to get with the chain? If the chain runs can be made (and kept) very close to straight, #25 chain is a valid option. But if not, #35 is more forgiving of misalignment.
On the other hand, Stronghold. #35 chain would be my gut call, and I've seen Stronghold break that for a variety of reasons.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
SoftwareBug2.0's Avatar
SoftwareBug2.0 SoftwareBug2.0 is offline
AKA: Eric
FRC #1425 (Error Code Xero)
SoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant future
First, why 4 wheels? 6 or 8 would be what most people expect on that type of drivetrain.
Now, to answer your question, #35 would be the safe choice, you may be able to get away with #25 but it would give you a low factor of safety.
Unread 11-17-2016, 11:55 PM
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
For 6" in wheels I'd recommend 18 or 22T sprockets @ #25 chain.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 11-18-2016, 12:03 AM
Billfred's Avatar
Billfred Billfred is online now
4901 used Team 221 double 17T #25 sprockets with 8" pneumatic wheels (hubs were AndyMark, tires were an Amazon find), center dropped 1/4" on 1x3 tubing. That worked well once we got past some master link teething problems, but it's important to note we supported both ends of the axle with bearings and didn't cantilever them. Could we have gotten away with cantilevered axles? Maybe, but we knew after the Team Cockamamie Ri3D build that we wanted a robot that could be driven fearlessly.
Unread 11-18-2016, 12:15 AM
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
Rookie Year: 2007
cj3958 will become famous soon enough
A lot of people have already said this, but as far as chain goes, use #35. Especially since its off season. You can get away with #25 if you know what you are doing but you will be constantly fighting it. For example, if your chassis deflects(as all chassis do) then the center to center distance on the axles(and therefore the sprockets) will either get bigger or smaller. When this happens, #25 chain is much more likely to jump than #35. If you are clever and manage that problem you can use #25, but it needs to be taken into careful consideration. IMHO it is not worth it.
As to what size sprockets, it all depends on what gear ratio you want. I would use the JVN gear ratio calculator and put in the gearbox you want to use etc. to determine the best sized sprockets for your application. The important thing is to get enough wrap around the sprocket and to have the correct ratio so that you don't burn out motors.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 11-18-2016, 09:30 AM
jlbimson's Avatar
jlbimson jlbimson is offline
AKA: Joshua Bimson
FRC #1678 (Citrus Circuits)
Team Role: CAD
Rookie Year: 2014
jlbimson is just really nicejlbimson is just really nicejlbimson is just really nicejlbimson is just really nicejlbimson is just really nice
Just make sure the chain is tight enough, so it doesn’t do this.
Unread 11-18-2016, 09:39 AM
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
Rookie Year: 2012
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
We have always used #35 chain for drive train and tend to use 22 tooth sprockets on the wheels. This gives plenty of teeth while still being small enough to fit on a 4 inch wheel. Our size of choice for general wheeled drive trains. Last year being the exception as we had treads.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 11-18-2016, 10:22 AM
Chris is me's Avatar
AKA: Pinecone
For WCDs, your options are 18T or 22T for #25 chain, or 12T for #35 chain.
The bigger the sprocket, the less chain "stretch" (pin wear) you have to deal with, and the easier it is to keep in tension. The tradeoff is more weight and less clearance.
It is honestly not that hard to keep 25 chain aligned and tensioned if you plan ahead and don't build sloppy drivetrains. The challenges are often overstated. I would generally recommend starting with 25 and switching to 35 chain if you have any problems with the 25 chain - the weight penalty is pretty big.
This year, especially if you had larger pneumatic wheels, the rough driving over defenses led to more chain and sprocket damage than normal, making 35 chain a safer choice, particularly for big wheels which place more load on a sprocket and chain (all other things equal). For 6" wheels, you are probably okay with 22T #35 chain. This the size my team ran and we never had issues apart from having to tension it repeatedly. For 4" wheels, or 6" wheels on a flat field game, 18T #25 chain can work just fine too with a bit more clearance.
This does not work for west coast drivetrains - a 22 tooth 35 chain sprocket is bigger than 2 inches in diameter and will not fit within the profile of the tube. If there is a belly pan placed below the tube (as is common on most WCDs) the chain will not have clearance.
Unread 11-18-2016, 11:06 AM
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
The chain could be run outside the drive rails.
Being correct doesn't mean you don't have to explain yourself.
Unread 11-18-2016, 11:52 AM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Do you mean on the same side of the tube as the wheels, or just not inside the tube?
"It's taking longer than expected, which was to be expected."
Unread 11-18-2016, 12:24 PM
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
If one wanted to run a tradition WCD setup with 22t #35 sprockets, then they would have to cut into the bellypan to allow chain clearance, which reduces the strength of the pan. Otherwise, they could cut only small slots for the sprockets and assembly the chain around the bellypan, which is a pain.
12t #35 sounds pretty good to me. We horribly screwed up a 2013 offseason WCD, but because of 12t #35 sprockets it still drove just fine.
<Now accepting CAD requests and commissions>
Unread 11-18-2016, 01:29 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The same side of the tube as the wheels.
I understand what you and Chris are saying. I'm just saying that if a team had some legitimate need to use sprockets with a larger diameter than the width of the tubes, the chain can be placed on the outboard sides of the drive rails (between the drive rails and the wheels). You sacrifice some of the spatial economy of a WCD (particularly those with gearboxes designed for interior chain runs), but it would facilitate the use of larger sprockets/pulleys.
1712 used 12t #35 chain in both 2015 and 2016 and never had a single drive chain issue.
Unread 11-18-2016, 02:09 PM
Rookie Year: 2013
If you did that, couldn't you go with dead axles on the outer wheels? Otherwise, I'd be concerned about putting the wheel so far out from the bearing supports.
  #15   Spotlight this post!
Unread 11-18-2016, 02:13 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
One wheel on each side would presumably still be powered directly off the gearbox shaft, so that wheel would still need to be live axle. The others could potentially be switched to dead axle.
I'd like to emphasize I don't really endorse this design choice in general. I'd much rather just use smaller sprockets and be able to protect my chain inside my drive rails and above my bellypan. This is only if, for some reason that I cannot currently contemplate, a design bound you to using sprockets larger than the width of your drive rails AND bound you to a "west coast" style drivetrain.
