Custom Gearbox Without Automated Machining?
My team does not have any access to a CNC, water jet, laser cutter, etc. The best tool we have to machine parts is a Bridgeport mill without DRO. I am wondering if anyone has experience making custom gearbox plates with limited automated machining capabilities like us. If we use a calipers to measure, and a center punch to mark the holes, is it possible to obtain center distances that will be accurate enough for the gears to mesh properly?
Re: Custom Gearbox Without Automated Machining?
You should be able to get the precision needed using the dials on the handwheels.
Since we normally use R8-size bearings that have a 1.125" OD, it may be a bit difficult drilling the bearing hole. I'm not super smart with machining, so I could be wrong, but it seems like a 1.125 annular cutter might be the easiest way to cut those holes. (a machinist should chime in here).
It really depends on the tools you have.
What will you use for the bearing holes? In a CNC you would use something like a 1/4'' endmill. Using that i doubt you can get good results with a manual mill. If you have a good enough way to make nice 1.125'' holes, i'd think that you should be ok. With that said, remember to add the 0.003'' to the distances of the pitch diameters for smoother runs in your gear. We recently learned that lesson the hard way. |
Team 1991 recently got a 1.125" end mill and have been using a 1.125" step bit that worked flawlessly. I'd suggest getting the step bit because it can also be used in hand drills. I'm not by any means an expert machinist but have used these both with no issues with the hole or spacing.
Hi there,
Yes, last year my team manufactured custom gearbox plates on a traditional mill, even though we did CAD them first to make sure that they fit everything properly. It's a pain but if you have a capable machinist you should be fine. |
It's possible if you know what you're doing with the Bridgeport and pay attention to backlash.
To make the bearing bore, I'd probably use a boring head. If you don't have one and don't want to buy one, you can also buy a 1" drill bit ($10 for the cheapest reasonable one) and a 1.125" ream ($50). I wouldn't use calipers and a punch. The center to center spacing of the gears needs to be within a few thousandths for the gears to not turn to dust in a short period of time. |
Your pre drill should be 2-3% smaller than your finished hole. 1-1/16" in this case. |
Just use the dials on the handwheels. Ordering a DRO is in your best interests, as they save a massive amount of time that is otherwise spent worying about backlash and tracking position. A "competent" machinist will not need a DRO, but it helps a ton for students who are learning. Add 0.002" or 0.003" between gear bearing holes to make sure that small tolerances don't kill the gearbox.
I usually just use a 1/2" drill, followed by a 3/4" endmill and then a 1" endmill to bring the hole larger, then finish with a 1.125" endmill. This makes a tight slip fit for 1.125" bearing OD, although not a press fit. You should always seek to retain bearings on a shaft with "positive" retention, which is things like shaft collars, screws, etc. You will not usually need to make a custom gearbox. For drivetrain, I urge you to go COTS all the way to save time. For anything else, try using clamping gearboxes and bearing blocks from Vex, unless it's super heavy-duty. After exhausting those options, then, I would look into custom. Follow KISS principles in design when manually machining a gearbox. |
#10
Machinist were building gearboxes way before CNC and DRO although those are great tools if you have them. You can lay them out with a machinist scale and a scribe. Youtube is an incredible resource for this kind of stuff. Here a couple of videos comparing the different methods. I would recommend machining the side plates in pairs the whole match.
Hole layout part one Hole layout part two On youtube: mrpete222 has many great videos on old school machining. THATLAZYMACHINIST is another good source. |
#11
This Old Tony is another good resource for machining. |
#12
https://www.youtube.com/user/ksruckerowwm He's even milled gears for a blacksmith blower using a horizontal mill and dividing head. No DRO on that mill either. |
#13
Is it possible? Yes, especially if you have a machinist that understands backlash in the handwheels and a mill that's been taken care of.
Is it the best use of your resources? Color me skeptical. Unless you have a very specific need, finding a COTS option would likely be better use of your finite time and machine access during build season. Making a gearbox plate manually is time consuming, and there's a noteworthy chance that you'll have to correct mistakes in the initial attempt (or even start over from scratch). |
#14
Bridgeport? Want to also do other bearing sizes? Get a cheap boring head. You'll be able to make A+ holes of any size.
#15
All of the gearboxes used on 716's robots are made on a manual Bridgeport. I am still making them as, at least for us, it is lower cost than buying. I have upgraded to a DRO to make it easier (Shooting Star BT-2, excellent quality, easy to install). I recommend a boring head for the bearing holes.
Check out my gearboxes in the white papers. All have been made on manual machines. |
