Go to Post Your iphone may be more intuitive for some of your students than a screw driver. - Isaac501 [more]
Unread 20-11-2016, 20:06
godkane godkane is offline
FRC #3875
godkane is an unknown quantity at this point
[FTC]: Using multiple sensors of same type
I got tired of not being able to read two color sensors or two sonic sensors, so I re-wrote the code to get them to work as expected.
In configuration, make sensor "I2C Device".
Initialization is hardware map, device name, and configured address.
color = new RedStormColorSensor(hwMap, "cb", 0x40);
range = new RedStormRangeSensor(hwMap, "rf", 0x2a);
Unread 21-11-2016, 08:28
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Re: [FTC]: Using multiple sensors of same type
Can this be used for Adafruit Color sensor?
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
Unread 21-11-2016, 08:56
FRC #3875
Here is the device I think you are talking about: https://cdn-shop.adafruit.com/datasheets/TCS34725.pdf
I have seen other libraries support it, so I would guess it could.
You would have to change RedStormColorSensor.java to match the registers in the datasheet on page 13. Let me know if you have any issues with what the code is doing.
Unread 21-11-2016, 12:02
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Because the Adafruit color sensors have a fixed, non-changeable I2C address, you need to use an I2C multiplexer. This code I wrote lets you use Adafruit color sensors over a multiplexer.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 21-11-2016, 16:19
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Thank you . I already have multiplexer and test code (not mine) that worked. I was just asking because original post didn't specify which sensors affected and it would be cool if Adafruit Sensors with fixed I2C address can be used with just code without needing extra hardware
