Go to Post According to a 6 year old I once met at a demo, our FRC machine was not a robot because, "How can it be a robot if it doesn't have a face?" - Jared Russell [more]
Unread 20-11-2016, 21:27
lundeby lundeby is offline
FRC #4388 (Ridgebotics)
Rookie Year: 2013
lundeby is an unknown quantity at this point
GPD Win for demo robot driver station
We have a T-shirt shooting robot and some other robots from prior seasons that we use for marketing the team. Our normal driver station is a bit large for convenience when there is no surface to place the driver station. We've been looking for some type of portable solution.
I just found this device:
https://www.youtube.com/watch?v=7C51mkucrnc
Has anyone given that device a try for running the driver station software? BTW, even if it works, I get a bit nervous about that GPD Win device getting dropped or walking off. But, if it worked, it would match our needs.
Does anyone have any other suggestions for a very portable driver station? Some sort of portable display & handheld controller is wanted. It would be possible to attach a handheld controller to a small display and run cables to a small PC in a backpack.
I know some people have looked at Raspberry Pi running Linux. Ideally we would stick with Windows for simplicity.
Thanks,
Bruce
Thanks,
Bruce
Unread 20-11-2016, 21:38
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Re: GPD Win for demo robot driver station
Personally I would swap out the control system for a R/C radio like this one. No boot up times, it's super portable, inexpensive and durable. You can use this relay to trigger the solenoid. It's the same system most battlebots use.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 20-11-2016, 22:11
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
The GPD Win certainly seems like an interesting option if you want to stick with windows, but I'm not sure it's as hard as you're making it out to be. The absolutely wonderful QDrvierStation works great, even on a raspberry pi (or so I'm told). Add a little battery and a battery protector board and you'll be great. You could even 3D print a cute little case and cannibalize an older screen and a joystick for it.
If you have your heart set on windows, I think the GPD might be your best bet in this case. Another member of F4 3D printed side controllers to go around his Suface tablet very similarly to the Razer Edge Pro, but that's quite a janky solution, I would not trust that several hundred device to my own 3D prints, even with my crappy printer. If you use anything other than the default dashboard, including Smart Dashboard or the LabView Dashboard, you will not be able to see that reasonably. The ability to hit the enter button in case of emergency also might be an issue, but you'd just have to get a feel for that. I would guess that the built in joystick would just register as USB internally, but I would ask the manufacturer before hand. Also, I'd hope you can operate all the functions of this yourself, otherwise having another joystick connected to it could be a pain.
Anyway, food for thought, and I think this could turn out well if you consider your options.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 24-11-2016, 01:21
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
Rookie Year: 2010
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
I know its already been mentioned, but qdriverstation can be run on an android phone also - this may be your best bet for a portable driverstation using the FRC control system.
Unread 04-12-2016, 17:40
rlounds's Avatar
rlounds rlounds is offline
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
rlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to behold
The Raspberry Pi 2/3 can run a core version of Windows 10 if you're interested. I would recommend the Pi 3 due to it's integrated WiFi and I'm almost certain is can run the DriverStation software.
Head of Public Relations & Operator for FRC Team 865, Warp7
2016 GTR-C Quarter-Finalist (1310, 1325, 865)
2016 North Bay Regional Quarter-Finalist (2185, 4716, 865)
2016 Waterloo Regional Quarter-Finalist (2702, 5631, 865)
Unread 04-12-2016, 18:47
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Have you seen andymark's cheap and dirty control system? It has the transmitter plus all the other peripherals for electronics (fuse block, etc.)
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
