Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Unread 11-21-2016, 05:15 PM
rlance rlance is offline
FRC #5550
rlance is an unknown quantity at this point
Team 5550 - Fall Project
We decided to try using those omni-directional wheels and make a holonomic drive robot. Here is a video of what we have so far. Great learning experience for the kids. Does anyone have any concerns about the wheels being at the corners like we have them?
https://youtu.be/c_J0yFwFDXM
Unread 11-22-2016, 02:28 AM
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Team 5550 - Fall Project
Looks good. Two suggestions though:
1. It looks like the wheels are protruding outside of the frame perimeter (assuming there would not be an additional superstructure to increase the frame perimeter). According to 2016 rules, that would be an illegal starting configuration.
2. Right now when driving straight forwards or sideways you only have 2 motors running at a time, which is rather inefficient. Combine this with the fact that you're using omni wheels means you will get pushed around like nobody's business. If you turn each module 45* so they are forming an O around the chassis, when moving forward you will have 4 wheels providing sqrt(2)/2 of force for a total of 2*sqrt(2) of force, effectively increasing your force by sqrt(2). This should make your drivetrain even faster when going straight forward or sideways and make it slightly better in a pushing match (though omnis are notorious for losing pushing matches).
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 11-22-2016, 07:26 AM
roboruler roboruler is offline
Rookie Year: 2010
roboruler is infamous around these partsroboruler is infamous around these parts
The allowable "frame perimeter" is based on the size of the entire robot, think of it as a box of a certain size that the robot needs to fit into. It is not dependent on the actual size of the frame/chassis/drivetrain.
If you apply that logic you are basically ruling all cantilevered wheel drivetrains ie WCD illegal( excluding bumper mounts)
This is a fun, valuable learning project rather then something that will be ever used in a competition.
This is a terrible style of drivetrain to use in any season( even in 2015 were it is unnecessary) so I don't believe they are intending for it to be legal.
Unread 11-22-2016, 07:39 AM
Ari423's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
If you apply that logic you are basically ruling all cantilevered wheel drivetrains ie WCD illegal (excluding bumper mounts)
Originally Posted by 2016 Game Manual R2
The ROBOT (excluding BUMPERS) must have a FRAME PERIMETER, contained within the
BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT.
Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not
considered part of the FRAME PERIMETER.
Emphasis mine. I'm not a robot inspector so my opinion is only my opinion, but I would argue that a spinning wheel or axle is not a "fixed, non-articulated structural element" and therefore not part of the frame perimeter. I think the "excluding bumper mounts" exception you made is important, because the bumper mounts are fixed, non-articulated structural elements and therefore count in the frame perimeter, extending it past the wheels of a WCD. That is why I suggested that if they do choose to use this drivetrain or something similar in competition, they should add an additional superstructure (like bumper mounts) to increase the frame perimeter past the wheels.
2013: Programmer
Unread 11-22-2016, 09:53 AM
FRC #5550
Thanks for all replies
If we did try and use something like this next year's game we would definitely add a structure to extend the perimeter if bumpers are needed for the game. Which somewhere it was mentioned that bumper mounts were not included in the KOP drivetrain this year.
We had a whole discussion on which direction is fastest with this set-up and if speed was an issue we would definitely either make one of the corners the forward direction for the robot or do the 45 degree angle thing.
Just curious if you think all holonomic drivetrains are terrible or just omni-wheels ones, or just because of the way we have ours attached or placed on the frame. If you could clarify, that would be helpful for us.
Unread 11-22-2016, 10:27 AM
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Holonomic (4-omni) drivetrains are generally bad because there are better, more efficient, or higher traction options. Mecanum in particular is better than a 4-omni holonomic drive, with the same general setup. It's a bit more expensive, but more efficient (If anyone knows the exact theoretical numbers, please let me know.)
So yeah, in a competition (and you reaally wanted to use omnidrive), I would look into using Mecanum instead of this setup.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 11-22-2016, 10:54 AM
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
I challenge you to show me the math (or at least the reasoning) to why you believe Mecanum drives to be more efficient than Omni drives.
Hint: Consider both drives moving not only in "straight" directions, but also diagonals.
As for traction, Vex quotes a CoF of 1.0 for their Mecanum wheels and a CoF of 1.1 for their Omni wheels.
Being correct doesn't mean you don't have to explain yourself.
Unread 11-22-2016, 11:13 AM
Captain
AKA: Nick Schatz
Rookie Year: 2014
...Yeah :|
Alright, that'll teach me to repeat information without a source and critical thinking. Drawing the vectors makes them look like the same.
Then, why does one never see a 4-omni holonomic drive used in FRC?
Unread 11-22-2016, 11:21 AM
FRC #5550
...Yeah :|
In last year's game if your robot's goal was to collect balls and put them in the lower goal as fast as possible, wouldn't the 4-omni holonomic be the fastest option. You could easily avoid shoving matches by zipping around the slower robots. Am I missing something in that thinking, because I think "Nick the Brick" poses a good question.
Unread 11-22-2016, 11:23 AM
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
...Yeah :|
You do occasionally. But why go through the hassle to build that frame when you could slap mecanums on a more traditional frame.
Unread 11-22-2016, 11:55 AM
FRC #5550
I think that putting this frame together was a whole lot less hassle than putting mecanums on the KOP drivetrains. Maybe there are already holes on that frame for mounting a motor and gearbox on each wheel. Even if it did we didn't have those gearboxes in our stock. We had plenty of planetary gearboxes and mounts for those gearboxes to make it fairly simple to build.
Unread 11-22-2016, 12:58 PM
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Because "easily avoiding shoving matches" is a lot harder than you're making it sound.
A well driven 4-8 wheel drive is easier to build/program, and just as good as a non-swerve holonomic drivetrain, if not better in 99% of all scenarios in FRC.
Even in 2015, if on Team 20, we could go back and do it again, we would not have gone with a mecanum drive that year, even with the lack of defense. It wasn't necessary, it caused us to spend too much time working on things that weren't scoring mechanisms, and occasionally tethers would get caught in the rollers of the wheels.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 11-22-2016, 03:10 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
If you work with a team in the near future, for their sake, I suggest you watch this video and read this thread.
Many teams had to redo their bumpers and frame perimeter either late in the build season or on the first day of a competition because they interpreted the bumper rules the same way you've described them.
"It's taking longer than expected, which was to be expected."
Unread 11-22-2016, 08:36 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
...Yeah :|
Back in FIRST antiquity the early/mid 2000s, you did see more holonomic drives than mecanums. Prior to the 2007 season, there weren't really any COTS options for mecanum wheels, so the few teams that used them had them custom made (namely 357). In the fall of 2006, AndyMark released the first FRC-specific mecanum wheel, and it became a bit of a cultural phenomena within FIRST. At the time, the COTS omni-wheels (also primarily sold by AndyMark) were still several generations behind what they are today, and weren't the greatest option, so when combined with the hype of the mecanum wheels and the relative ease of using a mecanum drive with a "standard" rectangular frame made them the preferred option. Mecanum drives never really looked back from there in terms of being the default choice for teams looking to move sideways.
Additionally, there is one major benefit of mecanum wheels when compared to omni set-ups when it comes to uneven flooring. Unless you're robot has a suspension or is doing some really fancy sensing and drive automation, generally speaking both mecanum and omni wheeled set-ups are reliant on each of the wheels being constantly in contact with the floor AND having a similar load on each wheel. If one wheel has a higher load on it, it will have more traction and exert more force than the other wheels, which can cause some unpredictable driving. Naturally, even worse examples of this occur when a wheel completely loses contact with the floor. Mecnaum wheels have a benefit that they can "climb" obstacles on the floor if approached dead-on such that both leading wheels make contact (more or less) identically. Think of a mecanum wheel rolling up a ramp. That type of maneuver is much more difficult to pull of in an omni-wheel set-up with the wheels spaced every 90 degrees. Thus why you saw mecanum wheeled robots climbing the bumps in 2010 and 2012, for instance.
And to answer your implicit question regarding 3 vs 4 wheeled (or even 5+) omni drives, think back to that previous paragraph. The reason many teams, such as 1114 in 2015, opt for a 3-wheel omni drive ("kiwi drive") is simple. It takes 3 points to make a plane. With only 3 wheels, it guarantees that all 3 of your wheels are in contact with the ground at all times. With 4 or more wheels, even small obstacles in the field can cause a wheel to lose contact with the floor and for erratic driving. I found this out the hard way in 2005, when my team at the time (116) built a 4-wheeled omni drive system, and even the small plastic loading zones (0.5" thick?) were enough for our wheels to sometimes lose contact with the carpet, which caused driving issues. Mecanum drives will also suffer similar consequences if they don't approach obstacles so that all 4 wheels remain in contact with the ground (plenty of teams had issues with the scoring platforms in 2015 if they contacted with only 1 wheel). Conversely, the biggest advantage today of a 4-wheeled omni drive is the simplicity of the frame construction (don't have to worry about a triangular drive base). Depending on the frame perimeter and sizing rules, there have also been points in time where a triangular frame would be space inefficient (or result in significant portions of your robot overhanging beyond your drive base, causing instability issues). Also, there was a time where the limitations on CIM motor quantities were capped at 4, meaning teams would opt to find ways to include all 4 in their drivetrains (difficult with 3 wheels).
  #15   Spotlight this post!
Unread 11-22-2016, 10:37 PM
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Not exactly on topic, but if you guys are trying to evaluate drive train options, I would just like to point out this great video starting from 48:38 and continuing for about 5 minutes. https://youtu.be/MW6KqtDR9_U?t=48m38s
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
