Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 23-11-2016, 13:03
Ubspy Ubspy is offline
FRC #2335
Ubspy is an unknown quantity at this point
Can't deploy GRIP code to RIO
Hello, I'm trying to deploy my GRIP code to the roboRIO, but I always get the same error.
I've tried deploying it from Ubuntu 14.0.4 LTS and Windows 10.
I don't have any code currently deployed to the roboRIO to do anything with the published values, could that be the issue?
Here's the error I get:
/usr/local/frc/JRE/bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
Nov 23, 2016 2:55:36 AM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.5.0-rc3
Defaulting Uptime to NOIMPL due to (java.lang.UnsupportedOperationException) Implementation not available in this environment
2016-11-23 02:55:45.117:INFO::main: Logging initialized @-1ms
Nov 23, 2016 2:55:51 AM edu.wpi.grip.core.GripCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[main,5,main]
com.google.inject.CreationException: Unable to create injector, see the following errors:
Error injecting method, java.lang.NoClassDefFoundError: java/beans/SimpleBeanInfo
at edu.wpi.grip.core.serialization.Project.initialize (Unknown Source)
at edu.wpi.grip.core.serialization.Project.class(Unkn own Source)
while locating edu.wpi.grip.core.serialization.Project
for the 2nd parameter of edu.wpi.grip.core.http.HttpPipelineSwitcher.(Unkno wn Source)
at edu.wpi.grip.core.operations.network.GripNetworkMo dule.configure(GripNetworkModule.java:25) (via modules: com.google.inject.util.Modules$OverrideModule -> edu.wpi.grip.core.operations.network.GripNetworkMo dule)
while locating edu.wpi.grip.core.http.HttpPipelineSwitcher
1 error
at com.google.inject.internal.Errors.throwCreationExc eptionIfErrorsExist(Errors.java:470)
at com.google.inject.internal.InternalInjectorCreator .injectDynamically(InternalInjectorCreator.java:18 4)
at com.google.inject.internal.InternalInjectorCreator .build(InternalInjectorCreator.java:110)
at com.google.inject.Guice.createInjector(Guice.java: 99)
at com.google.inject.Guice.createInjector(Guice.java: 73)
at com.google.inject.Guice.createInjector(Guice.java: 62)
at edu.wpi.grip.core.Main.main(Main.java:50)
Caused by: java.lang.NoClassDefFoundError: java/beans/SimpleBeanInfo
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java :760)
at java.security.SecureClassLoader.defineClass(Secure ClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader .java:455)
at java.net.URLClassLoader.access$100(URLClassLoader. java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java: 367)
at java.net.URLClassLoader$1.run(URLClassLoader.java: 361)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.j ava:360)
at java.lang.ClassLoader.loadClass(ClassLoader.java:4 24)
at sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:3 57)
at com.google.common.reflect.ClassPath$ClassInfo.load (ClassPath.java:274)
at edu.wpi.grip.core.serialization.Project$$Lambda$12/20503707.apply(Unknown Source)
at java.util.stream.ReferencePipeline$3$1.accept(Refe rencePipeline.java:193)
at java.util.stream.ReferencePipeline$2$1.accept(Refe rencePipeline.java:175)
at java.util.Iterator.forEachRemaining(Iterator.java: 116)
at java.util.Spliterators$IteratorSpliterator.forEach Remaining(Spliterators.java:1801)
at java.util.stream.AbstractPipeline.copyInto(Abstrac tPipeline.java:512)
at java.util.stream.AbstractPipeline.wrapAndCopyInto( AbstractPipeline.java:502)
at java.util.stream.ForEachOps$ForEachOp.evaluateSequ ential(ForEachOps.java:150)
at java.util.stream.ForEachOps$ForEachOp$OfRef.evalua teSequential(ForEachOps.java:173)
at java.util.stream.AbstractPipeline.evaluate(Abstrac tPipeline.java:234)
at java.util.stream.ReferencePipeline.forEach(Referen cePipeline.java:418)
at edu.wpi.grip.core.serialization.Project.initialize (Project.java:64)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at com.google.inject.internal.SingleMethodInjector$1. invoke(SingleMethodInjector.java:70)
at com.google.inject.internal.SingleMethodInjector.in ject(SingleMethodInjector.java:89)
at com.google.inject.internal.MembersInjectorImpl.inj ectMembers(MembersInjectorImpl.java:132)
at com.google.inject.internal.ConstructorInjector.pro vision(ConstructorInjector.java:120)
at com.google.inject.internal.ConstructorInjector.con struct(ConstructorInjector.java:90)
at com.google.inject.internal.ConstructorBindingImpl$ Factory.get(ConstructorBindingImpl.java:268)
at com.google.inject.internal.ProviderToInternalFacto ryAdapter$1.call(ProviderToInternalFactoryAdapter. java:46)
at com.google.inject.internal.InjectorImpl.callInCont ext(InjectorImpl.java:1092)
at com.google.inject.internal.ProviderToInternalFacto ryAdapter.get(ProviderToInternalFactoryAdapter.jav a:40)
at com.google.inject.internal.SingletonScope$1.get(Si ngletonScope.java:194)
at com.google.inject.internal.InternalFactoryToProvid erAdapter.get(InternalFactoryToProviderAdapter.jav a:41)
at com.google.inject.internal.SingleParameterInjector .inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector .getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.pro vision(ConstructorInjector.java:110)
at com.google.inject.internal.InternalInjectorCreator $1.call(InternalInjectorCreator.java:205)
at com.google.inject.internal.InternalInjectorCreator $1.call(InternalInjectorCreator.java:199)
at com.google.inject.internal.InjectorImpl.callInCont ext(InjectorImpl.java:1085)
at com.google.inject.internal.InternalInjectorCreator .loadEagerSingletons(InternalInjectorCreator.java: 199)
at com.google.inject.internal.InternalInjectorCreator .injectDynamically(InternalInjectorCreator.java:18 0)
... 5 more
Caused by: java.lang.ClassNotFoundException: java.beans.SimpleBeanInfo
at java.net.URLClassLoader$1.run(URLClassLoader.java: 372)
... 60 more
Any ideas?
