Go to Post I'm going through waves of excitment and panic all at the same time. - je2164 [more]
Unread 23-11-2016, 13:48
DRow's Avatar
DRow DRow is offline
VEX Robotics Marketing Coordinator
AKA: Dillon Row
FRC #0148 (Robowranglers)
DRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond repute
VEXpro 2017
Announcing the VersaPlanetary v2! This updated design is now held together with screws that install on the "back" (motor side) of the housing. This means that the gearbox can be disassembled to change gearsets without removing the gearbox output from the robot. Bosses have been added to the sides of the gearbox so when it is side-mounted you can "crank down" on the mounting screws without accidentally misaligning a ring-gear stage.
Note: The v1 & v2 input and output blocks cannot be mixed and matched - A v2 input block must be used with a v2 output block. Ring gears and gear kits are compatible between v1 & v2
In addition, base VersaPlanetary kits now include an optional pilot ring that will allow users to pilot the VersaPlanetary on a 0.75" hole, instead of relying on screw clearances to locate the gearbox. The plastic motor mounting plates now pilot on the input block.
The VersaPlanetary v2 is in stock now! Be sure to order yours now to prepare for the upcoming season. Check out this link for more information: http://www.vexrobotics.com/vexpro/mo...planetary.html
Team 148
Student (09-11)
Mentor (12-14, 16-?)
