Go to Post Flash drive? I was thinking floppy disks... :ahh: . - MrForbes [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 27-11-2016, 20:15
Mr. Rip's Avatar
Mr. Rip Mr. Rip is offline
FRC #1477 (Texas Torque)
Rookie Year: 1997
Mr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to all
VersaRunner
Texas Torque employs lots of VEXpro items but until recently had no formal program for training our new members in their use. Our team president suggested we design an activity that incorporates not only the VEXpro parts we employ the most but also requires the use of our machining capabilities.
We call the project the VersaRunner, though VersaWalker might be more appropriate given its lack of speed. It is made up of over twenty VEX parts, including the following: 2-stage VersaPlanetary Gearbox with a BAG motor, a section of 1" x 2" VersaFrame, two 3.25" VersaWheels DT, and two VersaBlocks.
https://drive.google.com/file/d/0B3t...ew?usp=sharing
The SolidWorks files for the project are available at this GrabCAD link.
You can also find the files, plus future updates, on our team website at http://www.texastorque.org/versarunner
Mr. Rip
Unread 27-11-2016, 21:20
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: VersaRunner
Mr. Rip
What are the funny zip-tie things?
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 27-11-2016, 21:23
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Team Role: Leadership
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: VersaRunner
I believe those are VEX EDR battery straps.
Unread 27-11-2016, 21:29
marshall's Avatar
Re: VersaRunner
Cool... did not know those were a thing until now. I need to spend more time ogling the VEX EDR parts.
Unread 27-11-2016, 23:02
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: VersaRunner
Interesting! Is that a 7.2 volt battery? How does the back part move? Is there a wheel not visible in the picture, or do the drive wheels just drag that part?
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 28-11-2016, 12:03
Mr. Rip's Avatar
Rookie Year: 1997
Re: VersaRunner
It is a VEX EDR 7.2 volt battery. We had some laying around. We use Anderson Powerpole connectors on everything.
We have a sponsor for plastics and use lots of 1/4" polycarbonate. There is a small polycarbonate skid, like a taildragger airplane, attached to the bottom at the back end. It would work just fine without the skid, but the rookies learn to use our table router while making this part.
Unread 28-11-2016, 15:44
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
Re: VersaRunner
This is really cool!
You posted a teaser photo earlier this summer, and it inspired our team to design something similar. We set the students off this month building 4wd "dragsters", and they're about half way done. Like your versarunners, the dragsters give students experience with measuring, cutting and riveting versaframe, grinding/milling shafts, drilling accurate holes, using the jig saw and drill, assembling, soldering, crimping, and programming. Our design is a bit unique, in that we tried to keep the unit cost under $20 so that we could build 8-10 at once, so that most students would have hands-on experience. As a result much of the mechanical and electronical parts are sourced from AliExpress, which makes programming a slightly bigger challenge.
We're aiming to race them in two weeks - I hope to post completed photos and design documents afterwards. Thanks again for the inspiration!
ID:	21308  Click image for larger version
Unread 29-11-2016, 08:23
Mr. Rip's Avatar
Rookie Year: 1997
Re: VersaRunner
Cool! I wish ours were cheap enough that students could customize their builds and keep them, but our goal was to include the experience with all the VEXpro parts.
Unread 29-11-2016, 11:12
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Re: VersaRunner
Very cool project. Great for rookie training. What does one VersaRunner end up costing?
We might "pirate" this idea for our rookie training next year. We've been using standard VEX parts with our own "soccer" game. Its fun but does not include the machining aspect which is definitely important.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 01-12-2016, 19:46
Mr. Rip's Avatar
Rookie Year: 1997
Re: VersaRunner
We just use spare parts we already have on hand, so no additional cost to the team. The VersaRunners are taken apart toward the end of our off-season.
Unread 29-11-2016, 11:24
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: VersaRunner
You have my interest... got a more detailed parts list?
Unread 29-11-2016, 11:52
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
Re: VersaRunner
I think the total cost went over our $20 by a bit, but I haven't done the final accounting. Will post the design and parts list in its own thread in a few weeks.
Unread 29-11-2016, 11:53
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: VersaRunner
What are the wheels?
Unread 29-11-2016, 12:14
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
Re: VersaRunner
You can PM me more detail questions. I don't want to take over Mr. Rip's thread.
