Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 28-11-2016, 17:46
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
Team Role: Coach
Rookie Year: 2010
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
[FTC]: Green Tread for Andy Mark Hulk chassis?
we finally got our Tilerunner Hulk chassis and didn't see any instructions for attaching the green tread to either the wheels or the ends to one another. We've used rubber conveyor belting before (FRC) and used a pin and buckle system to mate the two ends together. Any help would be welcomed. If you successfully glued these treads together or glued them to wheels please lmk. We got the fancy aluminum wheels and weren't sure what type of glue to use if at all. Any help would be appreciated!
Steve Miller
Coach 10756
Purple Vipers
