Go to Post New CAD computer one day and the 254 Build Blog Tech Binder the next? Christmas in July really does exist. - [more]
Unread 29-11-2016, 17:51
jberend jberend is offline
FRC #2102
jberend is an unknown quantity at this point
set screw identification
Hi - does anyone know the size of the set screw for a Tetrix axle wheel collar 739092? I was also wondering what Andymark motor would work well with a Tetrix motor mount and would spin faster for shooting balls.
thanks
Unread 29-11-2016, 17:59
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
The AndyMark NeveRest 3.7:1 has been shown to work for a side by side wheeled shooter.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 30-11-2016, 07:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: set screw identification
Based on some measurements of the photo, it looks like a 10-32 with a 3/32" allen drive.
Unread 30-11-2016, 07:29
pilleya's Avatar
pilleya pilleya is online now
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
If you are limited to purchasing only from Andymark the NeveRest 3.7:1 is your only real simple option and will work well with the Tetrix motor mount:
http://www.andymark.com/NeveRest-3-7...-p/am-3461.htm
The lowest reduction gearbox in the Helical gearbox series( 20,40,60) is the 20:1 which has a free-speed of around 300rpm. This is approximately twice as fast as the Tetrix DC motor, but unless you have a wheel with a very large diameter( or a two wheeled shooter) this will still be far too slow.
You could use something like a 20:1 and have another set of gears that increase the speed( something like a 1:3 or 1:4), but it ends up a little complicated.
Because the NeveRest motor is a 550 class motor there are quite a few different gearboxes available to use if you are ok with ordering from another supplier.
- The VersaPlanetary Gearbox which will allow you to adjust your flywheel speed easily: http://www.vexrobotics.com/vexpro/mo...planetary.html
-The 4:1 Planetary Gearbox for RS550 available directly from Banebots( Andymark is out of stock of this particular gearbox):
http://www.banebots.com/product/P60S-4-5.html
However neither of those two gearbox are compatible with the Tetrix motor mount, the VersaPlanetary has a few different mounting plates available which shouldn't be too difficult to integrate with the rest of the Tetrix construction system.
Facebook
Unread 30-11-2016, 15:13
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
From the FTC forum (2015 thread):
I just received an email from Pitsco that [one of] their vendor(s) mistakenly shipped collars with metric set screws that would require a 2 mm Allen wrench / "hex key", which is 5.04/64th's of an inch.
Per http://www.tetrixrobotics.com/gettin...ools_guide.pdf, the correctly-manufactured collars require the 1/16" (or 4/64") hex key.
Since the hex socket is 0.016" bigger than the 1/16" hex key, this explains why we are rounding the sockets.
It had also confused me why I had found that they were 4 mm set screws, but another Mentor found that a #6 screw fit perfectly - just luck of the draw.
We will segregate (discard) the metric collars. Pitsco has said they would replace the ones with the wrong set screws.
Most hardware stores have thread gages if you have a loose set scew to test.
If you don't know what you should hook up then you should read a data sheet
