Re: Where to purchase wire?
They re-stock a lot of wire, components and tools with new inventory (not surplus).
My only hesitation about Powerwerx is it looks like we have used of their 12AWG wire in the past, and it is a bit larger in diameter than the 30AMP power pole connector crips, so we always have to cut some of the strands off. If I remember correctly, the 30AMP power poles are rated to fit on 12AWG wire, so the sizing of Powerwerx wire might be a little bit off? Edit 1: While I'm at it, where to find 22AWG wire? Or more importantly since it is probably on one of the websites already linked, does anyone else even use it or just stick to all 18AWG? Edit 2: It's possible we were using 10AWG and just didn't know, but curious if anyone else had this issue with powerwerx wire. Last edited by dardeshna : 12-02-2016 at 10:33 PM. |
You can find 18AWG and 22AWG zip cord at Powerwerx. |
We use 22-2 stranded copper security system cable from Home Depot.
Although we haven't bought wire from Powerwerx, we bought all our powerpoles from there and I personally have used them for amateur radio stuff. Highly recommended. Last edited by frcguy : 12-02-2016 at 10:29 AM. |
We get ours from EBAY and have been very happy with it.
http://www.ebay.com/itm/500-FT-12-AW...AOSw7hRWQir D |
Less conductivity for a given cross section than copper (~60% less) and significantly more likely to break when bent (much lower ductility).
#11
2 conductor automotive speaker wire is the way to go. Be sure you're getting stranded wire.
We order from MCM Electronics: http://www.mcmelectronics.com/produc...6087-/24-16087 |
#12
. If you look in the description of that eBay listing it even says so. Less experienced teams may mistake 16GA equal to 16AWG - it is NOT the same. Make sure your wire is labelled __AWG. |
#13
Just got embroiled in a shop project, I need #8/4 copper to set a sub-panel. Recommendations in northern DE? Need 70', sheathed so I can run it along and then through a wall. Would like stranded to make some corners go easier.
#14
We have purchased from MCM Electronics (above) for years. While their cost might not be the lowest, they are always in stock.
I buy parts from them at work almost every week. |
#15
For single (not bonded) wire check out www.tinnedmarinewire.com. They have quality tinned marine wire for less money than lesser wire from other sites.
If you need 6 AWG wire for battery cable, I suggest moving up to "welding cable" with EPDM insulation. It is much more flexible than regular battery cable. Cheapest supplier is www.remybattery.com, where you can order it by the foot. While you are at the remybattery site, check out their battery terminal covers. The "starter terminal" cover or the "straight or angled" covers beat the heck out using electrical tape. |
