Re: Exhaust in Solenoids
No, the blue screw is a way to manually activate the solenoid valve. Unless it is pushed down or set in the lock position it shouldn't stop you from controlling it. A picture of your entire setup might be helpful.
Here is a link to the series catalog for your solenoid, it might give you some helpful information. http://content2.smcetech.com/pdf/SY3.5.7.9000.pdf |
I'm not sure whether you are wanting to power the cylinder action in just one or both directions, so I wonder if you are using a 4-way valve when you need a 3-way valve?
One of the best explanations I've seen on the different types of valves is this one, from a Halloween prop website: https://www.frightprops.com/faq/cont...explained.html. |
We tested it out, yet air is coming out from both valves (A and B) for one of the solenoids, but the diagrams show that it should only be coming out from one valve. For all the other solenoids, they work perfectly fine. We are not sure why this is happening, and are wondering if we need to buy a new solenoid.
Test manually: Does the solenoid change when you push the blue manual button shown on top of each one in your photo (with pressure applied to the input port of course)? Can you add code to toggle the solenoid value at the press of a button? Last edited by Mark McLeod : 04-12-2016 at 22:02. |
If you have constructed a system where no pneumatic air is used to retract the piston, then you will need a stopper on one valve port. For example: if only one port on the cylinder is connected to a valve, when that valve is diverting air to the other output port (say port 4), all connected air stores will be dumped. In this case adding a stopper plug to port 4 and making that port the "home" port will stop air from exiting when the system is being pressurized. This kind of set up can be used to save air when the cylinder has a return spring or other method of returning the piston to its starting position. A stopper can be made with a round urethane belt (tube) or use a tee fitting and connect 2 of the openings together with one tube to make a dead end, then connect the tee to your valve port. Dave |
