Go to Post I hope to be able to say, "WOW, we put a working robot in the crate". - MrForbes [more]
Unread 09-12-2016, 21:01
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Jigging Tubing Before Weld
I'm looking to eliminate the need for gussets on many places on the robot next year, hopefully cutting fabrication time down by a good amount. I was wondering how teams jig together their frames prior to welding (other than using gussets). A good example that I could think of would be 254. Any ideas?
Unread 09-12-2016, 21:31
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff is a jewel in the roughs-neff is a jewel in the roughs-neff is a jewel in the roughs-neff is a jewel in the rough
Re: Jigging Tubing Before Weld
You can do flat weldments laid out on plywood (with dummy shafts to preserve hole alignment). This was on 192, doing welded drivetrain module frames. As long as the board was flat, we didn't even really need to put much vertical constraint on the pieces - just using a pneumatic nail gun to put wood blocks in to hold everything in place was fine. We'd tack weld one side, then flip it over in the same jig to tack the other side, then finish the welds outside the jig. Some rework occasionally required for warp. All student welds, what do you expect.
On the Mini-Baja race car team in college, we ended up designing 3/4" particleboard jigs for the tube chassis with waterjetted cutouts in the exact design locations for each tube, and laying everything out before welding. It helped that we were using the same particleboard that our tube sponsor packaged the pieces with for transport (free), and that our waterjet time was free from the ME department in return for help with the upkeep.
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 09-12-2016, 22:51
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Ok, so why exactly are you wanting to do away with gussets? In a lot of cases, gussets can be stronger than just a weld and if you want to change something or you need to remove a tube, gussets can taken off and re-assembled at a competition. I'm not saying welds are bad, just making sure you consider the pros and cons.
Also, many teams assemble their tubing with gussets and weld the gussets onto it. That ends that whole quick modifications thing, but it's a great way to do fabrication.
As for your actual question, there's tons of different ways to do jigs. I assume you're welding square and/or rectangle box tubing and not round tubing. The more you can know about what you're welding before hand, the easier you can make your jigs to use. You can make just a flat plate with pre-drilled holes. Use the holes to clamp down and/or insert pins to locate the different parts. You can set the pre-drilled to the angles you might commonly use, like 15, 20, 25, 30, and 45 degrees. You'll have to figure out what angles you'll want to use. It depends on what kind of tolerances you want to hold, and what equipment you have. Do you have a mill? If you can put some time and effort into the jig, you can get very tight tolerances on the angle itself.
I'm working on making jigs for our car this year. We often spend more time on the jigs than the welds themselves, especially when the angle of the weld is especially critical.
"It's taking longer than expected, which was to be expected."
Unread 09-12-2016, 23:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Originally Posted by Cothron Theiss View Post
We often spend more time on the jigs than the welds themselves...
I just had this same conversation about two hours ago by e-mail on a totally different topic -- cutting PVC to provide proper tension to blackout curtains in frames of temporary cubicles. About three months ago, I cut over 50 pieces to one length and 100 to another, but spent way more time on getting the jigs right than on the cutting. (Actually, I did these on opposite sides of the same piece of lumber.) Someone else is interested in copying my pattern - glad I didn't chuck that jig!
Back to the welding jigs -- we only did a welded chassis one year, and I only went to one welding session. I recall that Bruce had a pretty generic clamp that could do just about any weld on square/rectangular tubing or c-channel and sometimes angle, as long as the pieces were within the same plane, or (with spacers) nearby parallel planes. It was a long time ago, but it seems that it had two square j-hooks which could be put in holes spaced every inch or so along a "plank". It required manual alignment of the stock for each weld, but it secured the stock well for the weld.
Unread 11-12-2016, 11:57
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I would say that 254 uses gussets extensively...they typically rivet their tube together with plate and then weld them in place.
See attachments. We regularly do the same thing.
ID:	21359  Click image for larger version
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 11-12-2016, 12:01
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Team Role: Mechanical
Rookie Year: 2015
arc25565 is an unknown quantity at this point
Our team primarily uses welding to attach parts together on out robot. To keep everything square I usually just clamp everything to the table or to a flat sheet of metal. I then do weld everything together and let it cool still clamped to the table. Vice grips are your friend.
Unread 11-12-2016, 13:17
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
1058 used an extensive amount of Versa Frame from Vexpro this year and a group of students welded our frame this year in house. We purchased a few packs of gussets from Vexpro that we could use to pre-assemble areas of the robot before sending it to the welding group.
It was quick and easy to replicate. After the first round of welding was complete the gussets were removed so the welders could finish the job.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 11-12-2016, 19:14
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
We'll be doing this next season as well.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 13-12-2016, 13:50
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
I have used very similar method for years. Large flat piece of plywood, with a great deal of care on the layout. Wood blocks (pieces of 2x2) pre-drilled and screwed into position to hold the pieces in place.
One problem with this style is if the fixture isn't symmetric, you may want to apply more weld to one side than you should. Also, aluminum heat expansion can be pretty large if you try to do your welds fully within the weld fixture.
If you have the ability to do what 254 is doing with the rivet then weld gussets, I think this is superior joint and fixture. Often "butt" style welds can be compromised during the rigors of play in FRC. I have personally experienced as well as witnessed a lot of failures with this style of joint. Using a weld in place gusset/strap piece is usually the remedy most teams that weld employ into their future designs.
Unread 13-12-2016, 19:34
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Our robot issues in the Michigan State Finals were directly due to multiple end-welds failing on our arm after a collision. Our long fix was to do exactly what 254 does - gussets welded in place. If you are into the physics of it, a simple free body diagram will show you how it decreases forces and torque on the weld by orders of magnitude.
Edit: And when you rivet the gussets in place, remember that it takes at least 3 rivets in a row to make a decent joint. 2 rivets in a row just makes for a wiggly mess.
Unread 12-12-2016, 02:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
As Anthony mentioned we use gussets almost exclusively for weld prep.
It saves so much time for us and the welder and it yields far superior results in terms of alignment/squareness/flatness/etc of the finished weldment.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-12-2016, 07:18
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Pre-weld assembly can be done in many ways as described by earlier posters. We have used all of the above.
When our design calls for an unusual weld angle or bearing location, we have also used jigs. Here is one: link.
Richard Wallace
since 2003
Unread 13-12-2016, 12:13
Team Role: CAD
Rookie Year: 2015
Sorry for the late response, but thanks for all the replies! Very insightful!
