Java compile error
We are moving to Java this year from Labview. Using last year's robot we are trying to code it using Java. On two separate laptops we get the same error when trying to run: PCs are both 64 bit running Windows 10
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Users\HammerHeads\AppData\Local\Temp\libwpilibJ avaJNI8681530594205079588.so: Can't load this .dll (machine code=0x34) on a AMD 64-bit platform at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(Unknown Source) at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.load0(Unknown Source) at java.lang.System.load(Unknown Source) at edu.wpi.first.wpilibj.hal.JNIWrapper.<clinit>(JNIW rapper.java:47) at edu.wpi.first.wpilibj.RobotBase.initializeHardware Configuration(RobotBase.java:170) at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:182) |
Re: Java compile error
This is for simulation mode? I don't believe it runs on Windows yet. If you meant to deploy to the robot instead of simulate, right click the project > Run As > WPILib Java Deploy
http://wpilib.screenstepslive.com/s/...to-the-roborio |
It sounds like your saying that the laptop has to be connected to the RIO, it's not. I was thinking that I could just use the run as a way to make sure the code compiles properly and I would just get an error that it could not contact the robot.
If you use the deploy function in the link above, or as Erik posted, that will build for the RoboRIO, and then fail if it can't connect. Trying to just run it on the desktop will compile as well, and then that error is showing when it is trying to run the code, and then failing because it's not running on a RoboRIO. So if you do get to that error message, the code will have compiled correctly, but its better to just do the deploy, and then let that fail to connect.
Thanks for clearing that up and responding so quickly!
Look forward to getting to the build site and running it on the real thing |
