Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 19-12-2016, 01:45
MrZ MrZ is offline
FRC #2832
MrZ is an unknown quantity at this point
Team 2832 Source Code Sharing
Hi, we are making our source code available on GitHub in case anyone wants to have a look. The 2015 and 2016 season's Java code for robot control is there. One somewhat unusual aspect was our attempt at a recordable autonomous mode.
Additionally there's some C code for controlling LED lighting strips on the robot via an Arduino hooked to the CAN.
https://github.com/FRC2832
Peter Zobel
Programming Mentor Team 2832
