Go to Post And please, never scorn a team that makes something outrageous, like a 4 speed 6 motor transmission. - Veselin Kolev [more]
Unread 22-12-2016, 06:58
rithinrv rithinrv is offline
FRC #0115 (MVRT)
Rookie Year: 2015
rithinrv is an unknown quantity at this point
pic: MVRT Off-Season Sheet-metal Chassis
Unread 22-12-2016, 07:22
BigHorse BigHorse is offline
AKA: Hersh
FRC #0548 (Robostangs)
Rookie Year: 2014
BigHorse has a spectacular aura aboutBigHorse has a spectacular aura aboutBigHorse has a spectacular aura about
Re: pic: MVRT Off-Season Sheet-metal Chassis
Originally Posted by rithinrv View Post
Let me just start by saying this is a great looking chassis.
To answer some of your questions:
Mounting electronics on the walls isn't a bad idea, but it can become very cluttered very quickly. I think I designed a chassis that had back wall mounted electronics but we never ended up cutting it.
Bumper mounts really depend on what you want to do. I have seen many different methods. Some teams do a bolt through a lightening hole, others will use angle iron to create a lip for the bumper to sit on.
We have been working on tensioning methods this last season. The best way we have found so far is to use fixed position tensioners on an array or line of holes. Slots and offcenter tensioners tend to slide out of place after frequent use, but the only thing that will ruin the tensions on a fixed position tensioner is the chain stretching. Whenever that happens we just move the tensioner down one peg and keep on driving. We have been fighting this problem for years and the method that requires the least maintaiance and headache is fixed postion tensioners with an array of holes.
We used them here if you want an example. The white plastic is delrin.
Unread 24-12-2016, 02:03
FRC #0115 (MVRT)
Rookie Year: 2015
Thanks for the suggestions, I really appreciate it!
Unread 24-12-2016, 16:25
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Rookie Year: 2011
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
A few tips:
-Close the box sections for the frame, it'll make them significantly stronger.
-Add in a bellypan, it'll help with torsional stiffness
-The split front part isn't very rigid either - extra support there (+bellypan) can help with that.
Check out some of 971's drivetrains for some good methods of sheet metal implementation. There are some helpful rectangular and octagonal drivetrains in the 2015 section that you should definitely check out.
Unread 07-01-2017, 02:10
FRC #0115 (MVRT)
Rookie Year: 2015
Update: CAD Files
https://drive.google.com/open?id=0B8...3liekFXR1g5ZEk
Unread 22-12-2016, 08:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Looking to mount electronics along the C channel wall of the sheet-metal(along the back). Anyone have any experience with this?
We toyed with something similar last year with a kit chassis. We found that not only is there too little space for very much, anything mounted in there will be hard to reach and hard to see for diagnostic purposes. We wound up moving the electronics elsewhere and put an air tank back in that volume.
Unread 22-12-2016, 11:25
andrew4130's Avatar
andrew4130 andrew4130 is offline
4130 Controls lead
AKA: Andrew Caporuscio
FRC #4130 (The Blue Devils)
Team Role: Electrical
Rookie Year: 2010
andrew4130 can only hope to improve
CAD? please pls?
Unread 22-12-2016, 11:56
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
What's the weight on that thing? Looks really beefy.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 23-12-2016, 01:09
FRC #0115 (MVRT)
Rookie Year: 2015
Around 23 pounds.
Unread 23-12-2016, 01:14
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Around 23 pounds.
Does that include CIMs and gearboxes?
<Now accepting CAD requests and commissions>
Unread 23-12-2016, 01:18
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Anand, theyes are getting good without you.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 24-12-2016, 00:54
Andrew_L's Avatar
AKA: Drübr Inc.
Rookie Year: 2011
Looks like they imported the STEP of the ballshifters and didn't change them, so it's likely they didn't even add mass properties, hence why Anand is asking about their weight inclusion.
Unread 24-12-2016, 02:01
FRC #0115 (MVRT)
Rookie Year: 2015
No
Unread 24-12-2016, 00:30
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Need to add bumper mounts and chain tensioners. Looking to use McMaster's snap slide latches in addition to L-channel for bumper mounts and McMaster spring chain tensioners. Anyone have any suggestions in this area?
I'm a big fan of these automotive panel nuts for sheet metal chasses. Just add 1/4-20 bolts and a cordless impact driver, and you have a super strong bumper connection that comes off in seconds.
