Go to Post I'm currently working on design for a bin made out of concrete that will not break for next year's competition... :D - dlavery [more]
Unread 23-12-2016, 13:51
TORNADES 3386 TORNADES 3386 is offline
FRC #3386
TORNADES 3386 is an unknown quantity at this point
Team 3386 frame autodesk inventor cad prototype
CAD Model of Tornades's Square Tubing Frame of the Drivetrain Design for various configuration. Material made out of T5 Aluminium. Various predrilled holes tapped 1/4-20. Various access inspection windows on each sides.
to see the cad click on this link below and download. https://drive.google.com/file/d/0B_z...ew?usp=sharing
Unread 23-12-2016, 14:27
Lireal Lireal is online now
AKA: Alex Colello
FRC #2141 (Spartonics)
Rookie Year: 2013
Lireal is on a distinguished road
Re: Team 3386 frame autodesk inventor cad prototype
Are those slots in the top and bottom of the tubing at the bearing blocks for wheels? I feel like having such large holes will seriously weaken the frame. You might want to decrease the size of the clearance holes for the shafts as well. You do not need that much space to adjust the chain tensioner if you calculate the correct chain length.
Unread 23-12-2016, 14:33
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Ok, so I'll be that guy. What alloy of aluminum? T5 only refers to the temper of the metal.
(I'll try and get on my laptop and actually look at the CAD later. I'm currently on my phone, so the material is all I can nitpick.)
"It's taking longer than expected, which was to be expected."
Unread 23-12-2016, 16:55
FRC #3386
We also though the same thing but after. A stress. Test we found a 5+ safety factor each tub have a maximum of 750 kg of static force
Unread 23-12-2016, 16:57
FRC #3386
Yes and the material it is aluminum 6061
