Go to Post This is how students can be inspired! - Rich Wong [more]
Unread 23-12-2016, 15:45
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Drill motors for go cart project
The STEM guys in my local school district are doing a project of making go-karts powered by drill motors.
There are a lot of you out there that have experience with drill motors. I'd like to collect some quality information links for them.
Short of bringing them here and saying "search on drill motors" any other resources they should be looking at?
They are building small 3' 6' carts to carry one driver on a fairly straight course.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 23-12-2016, 16:15
Billfred's Avatar
Billfred Billfred is offline
Re: Drill motors for go cart project
I used the guts of a Harbor Freight drill on my combat robot, though swapped with a NeveRest motor of the same size (those were the rules). I'd treat them like any other small-can motor, keep air going on them and use the clutch to keep it from stalling.
Unread 23-12-2016, 23:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
While I haven't tried to drive a robot with a drill motor, here is a piece of general advice I have given to our band & musically talented members for several years in operating tools:
Listen to the [drill/saw/other tool] motor running free. When you use the tool, make sure it runs no lower than one octave below its "running free" pitch. If the pitch gets any lower than that, back off.
Unread 26-12-2016, 03:00
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
For those not musically inclined and wondering the technical meaning, an octave is a doubling or halving of frequency. So he's saying don't run it below 50% free speed.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 26-12-2016, 12:13
tjwolter tjwolter is offline
FRC #5826
tjwolter is an unknown quantity at this point
drill motors for this application are touchy. You need to very firmly support the "outboard" end of the shaft or the planetary gearbox will strip. If I recall some prior misadventures you also have to lock the clutch by putting in some set screws. Or find older drills without clutches. These are harder to find and tend to be 7.2 volts. They are nice and frisky at 12v. But unless you are sold on drill motors may I suggest the humble Barby Jeep gearbox? Cheap. Durable. Can handle 24 volts for a while. So many around that a four wheel drive machine, which you will want, will be bargain basement.
You would be happier with the end result
T. Wolter
"Well, its never actually been successfully tested"
