Go to Post Basically, it just doesn't matter. - Mark Pettit [more]
Unread 12-24-2016, 11:48 AM
mkmeral mkmeral is offline
FRC #4191
mkmeral is an unknown quantity at this point
Roborio Connecting to Raspberry Pi
I am right now trying to get message from raspberry pi using roborio(java). I have configured Raspberry as web server, and i access to a file from it. In my computer (not wpilib) it works, I can get the data as I should normally do. However, when, try to upload the code below to the roborio i get the error below. Any suggestions? public void networking(){ // TODO Auto-generated method stub
try{
String wholetext = "";
URL oracle = new URL("http://10.41.91.109/a");
URLConnection yc = oracle.openConnection();
BufferedReader in;
in = new BufferedReader(new InputStreamReader(
yc.getInputStream()));
String inputLine;
while ((inputLine = in.readLine()) != null)
wholetext += inputLine;
in.close();
SmartDashboard.putString("Deger", wholetext);
}catch(Exception e){
SmartDashboard.putString("NETWORK:", e.getMessage());
BUILD FAILED C:\Users___\wpilib\java\current\ant\build.xml:71: Unable to find a javac compiler; com.sun.tools.javac.Main is not on the classpath. Perhaps JAVA_HOME does not point to the JDK. It is currently set to "C:\Program Files\Java\jre1.8.0_111"
Unread 12-24-2016, 01:01 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Roborio Connecting to Raspberry Pi
Install a JDK
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 12-24-2016, 01:12 PM
FRC #4191
It's already installed. I am also developing other apps on this pc, and they work fine. Also I tried the same code on eclipse console (java app) and it worked.So I do not think there's problem with jdk. Also without the jdk installed, eclipse gives an error at startup
Unread 12-24-2016, 02:12 PM
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Ok, then you just need to fix your environment variables. Change JAVA_HOME to the location of your jdk (C:\Program Files\Java\jdk_<version>). Then you should probably also edit your PATH for good measure: remove C:\Program Files\Java\jre_<version>\bin if it's there and add C:\Program Files\Java\jdk_<version>\bin and C:\Program Files\Java\jdk_<version>\jre\bin
Unread 12-25-2016, 02:26 PM
JamieSinn's Avatar
JamieSinn JamieSinn is offline
Student Mentor
FRC #1334 (Red Devils)
JamieSinn is an unknown quantity at this point
What is the stacktrace of the error? Without that we can't tell what the problem is.
Unread 12-25-2016, 05:54 PM
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
What?
