fast OPR computation with R using sparse matrix technology
Re: fast OPR computation with R using sparse matrix technology
Thanks for posting this Ether. Out of curiosity, have you quantified the time savings?
Then compare those to this. |
Any questions? |
I don't have any experience with R (on my to do list though). Here is what I think is going on, please correct me if I am wrong.
Stacy Irwin used Rs "solve" method to calculate season OPRs, more info here. She created functions to generate the A and b matrices and used R's "solve" method to get OPRs. I'm having trouble finding good documentation on this method, the best I could get was this. The problem is that this method requires A to be square, which it isn't. This method seems to use LU decomposition. Solving for OPRs after creating the A and b matrices took approximately 3 seconds. You used the sparseM package to calculate season OPRs. The key difference from Stacy's method was that you converted the A matrix into a sparse matrix and then used the slm method to get OPRs. This method uses Cholesky decomposition. Solving for OPRs after creating the A and b matrices took approximately 0.50 seconds. These results are roughly in line with the fact that Cholesky decomposition is around twice as fast as LU decomposition. Quote:
Let A be the 17842-by-2696 dichotomous (ones and zeros) design matrix of the overdetermined linear system corresponding to the raw qual match data (alliances & scores) in the file "8col Hill.dat". Let b be the 17842-by-1 column vector of alliance scores Let N be the 2696-by-2696 matrix of the coefficients of the normal equations N=A'A Let d be A'b Using Stacy's R code as a dense matrix performance baseline, it takes 10 seconds to create the N matrix and d vector, and another 3 seconds to compute the OPR from Nx=d Using sparse matrix technology, it takes 0.68 seconds to create the b column vector and the sparse matrix A, and 0.27 seconds to compute OPR from Ax=b. |
