pic: Quick-Change Chassis 2
Re: pic: Quick-Change Chassis 2
Great idea!
If I were going to do this, I'd invert the mounting, so that the modules came in from the carpet side. The reason is that that way, the load carrying the robot is transmitted through compression load of chassis components, not tension in fasteners - more fail safe, and would put less load on the fasteners. |
We used those same worm gearboxes in our arm this year, and we found they had a relatively low max output shaft torque rating. We sheared the worm shaft (or something like that) without putting what we considered to be excessive torque on the arm. And since they are non-backdrive-able, that could be a problem when doing hard direction changes with high CoF wheels. Make sure you take that into account when you design a robot around these.
Also if you're doing a drop-center 6WD, each wheel would be driven by one CIM so at any point you would only have at most 4 CIMs of power going into the ground. In pushing matches, if you get pushed onto your back wheels, you will only have 2 CIMs of power. Maybe you should look into a belt/chain connection on the modules to link them and transfer the motors' power equally between the wheels. |
What is your goal with this? Flexibility or maintainability?
If we use this concept, it will be for ease of assembly & quick repairs at the competition. Using nutserts and an electric screwdriver I think we could swap out a drive module in <1 minute.
We also thought about inverting the assembly, but that would make the mounting screws more difficult to reach. I've posted the CAD files (41 Mb, SolidWorks 2016) here, but this concept is not 100% done. We've built a previous version, but not this one. Just didn't have time before the Kickoff. ![]() |
Non-backdriveable means that torque applied to the output shaft will encounter sufficient friction that it will not turn the motor (with no voltage applied to the motor). It does NOT mean that the system cannot be driven in reverse from the motors. While I have obviously not spent as much time with your design as you have, I don't see this at all. As I'm picturing the fasteners, this would be a matter of switching the threads from the chassis to the module, with no net difficulty in assembly, other than the requirement to hold the module up as the machine screws are being threaded. If a few alignment tools were in place, even this could be accomplished with gravity. |
Changing out wheels could certainly be done more quickly than removing the entire module, and if you're blowing out motors/gearboxes often enough to require such quick repairs, then your problem isn't lack of ease of accessibility, it's more likely that the problem is that you're using the wrong kind of gearbox/ratio/lubricant. IMHO, a good drive system is one you shouldn't have to touch maintenance-wise (short of wheel/tread replacement) for the whole season. |
One other feature of a right-angle drive is it leaves a lot of open space in the center of the chassis. This could be big advantage if we need to integrate some sort of floor pickup mechanism. |
#10
This point I will grant you, however I would think you would want to consider using bevel gears instead of worm gears. While back-drive resistance is nice, worm-gear efficiency can be as low as 50%, compared to bevel and/or spur gear efficiency of 93%-98%. Back-drive resistance can always be accomplished with brake-mode on your speed controllers.
#11
I would be looking at iterations of your previous (low maintenance) drivetrain, not designing something that is less robust so your pit crew has something to do. |
#14
Worm gearboxes are not as "forgiving" as traditional spur gear drives, but we've had 3 years of failure-free use out of these Nordex drives. Interesting development: We can now back drive some of the older units a bit. I don't know if we'll use these gearboxes in 2017. Depends on the game & what strategy the team decides on. Great discussion points here on CD! |
#15
Also, the fact that some of your older gearboxes became backdriveable worries me. That means that either your worms or worm gears (or both) are wearing to the point that they have changed shape. I can only imagine that that means the gearboxes are less efficient. I wouldn't be surprised if this effects auto modes as the gearboxes wear throughout the season. |
