Go to Post Dean's "All Denim" (now referred to as "Deanim") look is apparently catching on. - AndyB [more]
Unread 02-01-2017, 17:07
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
WCP: 2017 Product Launch + MCC 2017
Back for more! Announcing our 2017 FRC Product Release. As a general disclaimer, most products are in stock. Inventory updates, CAD files and manuals will be going up throughout the week. Products that do not have an ETA:TBD date will be shipping by this Friday. If stuff is missing or incorrect, please email support@wcproducts.net or me directly here.
  • 2 CIM Flipped Gearbox & Dog Gears - Ever since FIRST decreased the size of robots in 2013, space has become one of a designer’s most valuable resources. FRC is a game of inches, and with the 2 CIM Flipped Gearbox you can save up to 5.5 inches of critical center floor space on your robot. To some that number seems small, but the smart designer knows that that’s enough to fit more game pieces, contain that hard to position control system module, or find more space to get that manipulator in place. This new gearbox designed to save space is battle tested by FRC 1323 in the 2016 season and is capable of using any wheel size from 3.5” up to 8”. Almost any ratio is achievable!
  • A whole new Roller System! - We came up with various end plugs, new pulleys and some squishy flexible wheels to help teams intake and move objects. Designed to work with anything from plastic balls to inner tubes, just put the plugs in the end of some round tubing, tighten down the bolt, and away you go!
  • GT2 Pulleys & Timing Belts - 24/36/48/60T pulley sizes added to the collection with ½” hex bores! Perfect for intake rollers and shooters, these pulleys & belts make for an ultra quiet, highly efficient subsystem. Pair them with our 12T pulley pinions and get 2:1, 3:1, 4:1, and 5:1 ratios or pair with each other to get your reduction right in the sweet spot you need!
  • Spartan Chain Tensioners - #25 and #35 chain tensioners for various systems such as elevators and arms. Just connect the tensioners to the chain loop, tighten the bolts to the perfect tension, and you’re good to go! Pioneered and battle tested by FRC Team 971!
  • More Sensors! - Dual Output Encoder, Absolute Encoder, Breakout Gyro, Talon SRX Breakout and Molex Headers - You won’t need anything else to control your robot after this!
  • 100T ⅜” Hex 32DP Gear - Another gear addition to our 32dp line. This gear is pocketed for max weight savings and anodized black. Now you can start your reductions off right with a huge 8.3:1 reduction when paired with a 12T pinion. That reduction would take up 5.7” in 20DP gears but can be done in a little over 3.5” with these 32DP gears!
  • Pocketed Gears - VEXpro gears pocketed for extreme weight savings, on average 50% per gear! Pocketed gears have been tested for strength and durability for years on teams such as 254, 973, 1323, and 971. In fact, Team 971’s 2016 robot saved about 2 lbs of weight just by lightening their gears! This was enough for them to add their hanging claw at the Championships!
  • Aluminum Wheels - An ultra light wheel designed to be used with any drivetrain you create! Available in 1.5” tread width for 3.5” and 4” diameter wheels!
  • Female Rod Ends - A lightweight Rod End perfect for FRC use. Designed to be used in tandem with any air cylinder to achieve the actuation you need.
  • Split Collars and Helical Beam Couplers- Split Collars allow teams to add and take off collars without disassembling the assembly. Beam Couplers allow for an easy way to couple sensors to mechanical assemblies without the risk of slippage.
  • CIM Timing Pulley - Want to use a CIM or Minicim with our HTD belt line? Now you can! This pulley interfaces directly with the 8mm output shaft of the CIM and makes starting off with belts easier than ever!
  • 6” to 8” Pneumatic Adapter - Love our 6” pneumatic wheels? Well, we added an adapter so teams can use 6” or 8” pneumatic wheels without changing the hub! Just slip on the adapter, add the 8” tire and tread, inflate and you’re good to go!
Updates to our Current Product Line
  • We can’t believe we didn’t have these items before! - CAN Connector, Talon SRX Encoder and Analog Breakout, Versaframe Linear Motion Gusset & Roller Chain Attachment.
  • Versaplanetary V2’s are now available!
  • The Spartan Board is now cheaper and comes with a gyro on every board ordered.
  • Our 32DP and GT2 Pinions are at our facility, they are being kitted and put on our shelves. They will be available by Friday. These pinions have an updated coating to them.
MCC 2017
  • We will be releasing another MCC Robot for the 2017 season. We expect to release the robot with full BOM for everyone to check out on 1/13/2017.
  • Please follow us on Facebook & Twitter to get Live Updates!
Videos and other resources, We are adding youtube videos and other design resources so teams can utilize VEXpro and WCP products easier.
  • GT2 3mm Timing Belts
  • Versachassis Design Video
Manuals & User Guides
  • WCP Spartan Board
  • GT2 3mm Belts
  • VersaChassis, more in Que
Community, if you have suggestions for stuff you’d like to see in manual form as a design resource or videos please email me directly @ rc at wcproducts.net.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
