Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 04-01-2017, 10:49
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
ANNOUNCING: Kauai Labs navX-MXP Upgrade, navX-Micro & SF2
Just in time for the FIRST FRC 2017 "Steamworks" season, Kauai Labs announces the following exciting upgrades and new products - designed to help teams Build Better Robots®.
All software items below will be available for download on January 7, 2017.
Classic. Must-have. Featured on Championship Robots.
navX-MXP is a mature, must-have navigation sensor for a FRC RoboRIO-based robot control system. Over a thousand FRC teams have purchased navX-MXP to enhance drive-train navigation, including several teams competing in the FRC 2016 World Championship Finals.
navX-MXP 3.0 - a free software upgrade to existing navX-MXP customers - includes these new features:
  • 200 Hz Update Rate
  • Full RoboRIO support for USB, in addition to SPI, I2C and TTL UART
  • New Linux library - great for integrating navX-MXP into a separate vision co-processor
  • Libraries for integrating nav-MXP into Android-based FIRST FTC Robots
Reduced size and cost. Great as a second IMU. Sold out on day one of FIRST Choice 2017.
navX-Micro is a new, smaller, lower-cost IMU, great for FRC and FTC teams with limited budgets.
navX-Micro also works great as a second IMU for measuring orientation of robot arms and other moving devices.
navX-Micro is software-compatible with navX-MXP and works with all RoboRIO libraries, which now include support for multiple simultaneous navX-MXP & navX-Micro devices.
New for 2017.
SF2 is a free, open-source software framework making navX-MXP and navX-Micro even more powerful - fusing multiple sensors together to help you build even better robots.
Available in LabVIEW, C++ and Java for the RoboRIO, the initial SF2 release enables Video Processing Latency Correction on FRC robots.
Unread 04-01-2017, 11:04
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: ANNOUNCING: Kauai Labs navX-MXP Upgrade, navX-Micro & SF2
This is the announcement I've been waiting for.
Thanks Scott!
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 04-01-2017, 19:22
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
This is amazing! Can't wait to try out the Vision Latency library!
Unread 04-01-2017, 23:22
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
Rookie Year: 2012
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
Some cool stuff!
Unread 05-01-2017, 10:53
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Are there any differences in accuracy between the NavX MXP and the micro? Does the micro support omnimount like the MXP?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 05-01-2017, 11:06
Software Mentor
AKA: Scott Libert
navX-MXP and navX-Micro are identical with respect to accuracy - the same Invensense MPU-9250 is on both, and the firmware that performs automatic calibration and other cool features like Omnimount is also the same.
The only significant difference between navX-MXP and navX-Micro is that navX-MXP adds (a) SPI and TTL UART interfaces, (b) IO Expansion and (c) MXP connector.
Unread 06-01-2017, 23:18
Software Mentor
AKA: Scott Libert
The 2017 navX-MXP and navX-Micro upgrades are now available.
If your navX-MXP is at a firmware version lower than 3.0.289, you are encouraged to update your firmware as well.
The 2017 Sensor Fusion Framework (SF2) library is also now available.
Unleash the hounds!
Unread Yesterday, 19:37
naldarn naldarn is offline
FRC #5257
naldarn is an unknown quantity at this point
The Labview information is difficult to find, http://www.pdocs.kauailabs.com/navx-mxp/labview-ae/
has nothing on it.
and if you go to the navx-micro for the examples, it takes you to github and shows you the c++ examples instead of Labview.
Unread Today, 01:10
Software Mentor
AKA: Scott Libert
has nothing on it.
Thanks for the head's up; the path to the labview AE URL is fixed.
As far as the navX-Micro examples, you likely found yourself to the FTC examples; there are separate FRC examples linked to as well on the navX-Micro Examples page.
