#16
Re: ANNOUNCING: Kauai Labs navX-MXP Upgrade, navX-Micro & SF2
For 2017, the location of the navX-MXP RoboRIO Java Library has changed, to match the new standard defined by the WPI Library for 3rd-party libraries. This new location is: C:\Users\<username>\wpilib\user\java\lib This actually makes things simpler to configure in Eclipse than in previous years, but it involves a change to the Eclipse library paths. Please review the RoboRIO Java Library instructions for Configuring Eclipse Library Paths, which have been recently updated to reflect this new location. |
#17
If Kauai Labs creates a Java tank drive "straight-line driving" example using the WPI Library RobotDrive class, would your team be able to spend some time testing it? I realize everyone's busy right now...
#18
Sorry for the slow reply. We'd be happy to. We are trying to get this to work right now, but are running into build problems just trying to test out the DataMonitor example. We followed the steps at http://www.pdocs.kauailabs.com/navx-...ibraries/java/ (three sets of eyes checked this) and are still getting an error: ...navx-mxp\java\examples\DataMonitor\src\org\usfirst\frc\ team2465\robot\Robot.java:3: error: package com.kauailabs.navx.frc does not exist [javac] import com.kauailabs.navx.frc.AHRS; Is there anything else we should check? This seems like a really basic thing. We've now spent two full meetings trying to figure it out. The navx-mxp jar path is right there in our Java Build Path, but its like it's invisible and gets letf out during the build. Code:
Buildfile: C:\Users\robotics\navx-mxp\java\examples\DataMonitor\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\robotics\navx-mxp\java\examples\DataMonitor\build
compile:
[mkdir] Created dir: C:\Users\robotics\navx-mxp\java\examples\DataMonitor\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\robotics/wpilib/java/current/lib/NetworkTables.jar: to build
[javac] Compiling 1 source file to C:\Users\robotics\navx-mxp\java\examples\DataMonitor\build
[javac] C:\Users\robotics\navx-mxp\java\examples\DataMonitor\src\org\usfirst\frc\team2465\robot\Robot.java:3: error: package com.kauailabs.navx.frc does not exist
[javac] ^
[javac] C:\Users\robotics\navx-mxp\java\examples\DataMonitor\src\org\usfirst\frc\team2465\robot\Robot.java:34: error: cannot find symbol
[javac] AHRS ahrs;
[javac] ^
[javac] symbol: class AHRS
[javac] location: class Robot
[javac] C:\Users\robotics\navx-mxp\java\examples\DataMonitor\src\org\usfirst\frc\team2465\robot\Robot.java:51: error: cannot find symbol
[javac] ahrs = new AHRS(SPI.Port.kMXP);
[javac] ^
[javac] C:\Users\robotics\navx-mxp\java\examples\DataMonitor\src\org\usfirst\frc\team2465\robot\Robot.java:135: error: package AHRS does not exist
[javac] AHRS.BoardYawAxis yaw_axis = ahrs.getBoardYawAxis();
[javac] ^
[javac] 4 errors
BUILD FAILED
C:\Users\robotics\wpilib\java\current\ant\build.xml:71: Compile failed; see the compiler error output for details.
Total time: 610 milliseconds
#20
We'd love to test the tank drive code, though. We have a test drivetrain wired and ready to go. |
#21
With your tank drive system, is it your goal to: - when stopped, rotate the robot to point to a particular angle? - or - - when moving, continue driving in a straight line? |
#22
We're using a naxX micro for our FTC robot so are familiar with the FTC examples (we have a consistent 100 point autonomous in FTC). We are just trying to translate that into FRC where we have much less experience. So, for instance, we may: (1) drive on a heading for X encoder ticks (2) stop, and turn in place (3a) drive on a heading for X more encoder ticks AND/OR (3b) drive using vision tracking for X more encoder ticks |
#23
Hi,
I'm using Labview (updated), and have just installed the library, but it can't find this file: Code:
FRIC_SF2_ProcessingLoopStatesTypeDef_I2C.ctl |
#24
Let us know how the testing goes. - scott |
#25
I would try reinstalling the navX-AE library again. Something must have gone wrong with your install. Is that the only file that can not be found?
#26
Sorry for the long delay, the SF2 stuff was put on hold while we had to work something else out, but now I'm back and remembered about the post. Yes, that is the only file missing, I installed it twice to try and work it out but it didn't fix it.
#27
https://github.com/kauailabs/navxmxp...ewae/_TypeDefs I would just check that you have your robot project file open when you place the navX into your robot code. As far as I know I have not heard of anyone else having this problem. Last edited by aeastet : Yesterday at 11:43. |
