Go to Post I can still remember how weird it was to look on the other side of our booth and see a kid in a suit tossing purple balls... - OneAngryDaisy [more]
Go Back   Chief Delphi > Technical > CAD
Unread 06-01-2017, 22:24
CrakinWise CrakinWise is offline
FRC #3200
CrakinWise is an unknown quantity at this point
3200 CAD Release
These are the designs made for a prototype drive team. We don't know what will become of it.
https://grabcad.com/library/unnamed-drive-train-1
Unread 06-01-2017, 22:27
FRC #3200
Re: 3200 CAD Release
Drive train*
Unread 06-01-2017, 22:51
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
A drive team made of robots driving another robot. That would be cool!
Seriously though, is there a reason that you went with TB Minis instead of TB Micros? If you're only using one CIM per gearbox I don't see the advantage.
Also, let me caution you against using independently powered modules on a 4WD. If you get into a pushing match and get pushed onto your rear wheels, you will only have 2 CIMs worth of power in your drivetrain and you are sure to lose. A belt or chain connecting the modules on the same side will help with pushing matches, as well as in case you have a motor or gearbox failure.
<edit>I realized after I posted that I only looked at the render so there may be a chain in the drive rail that's hidden in the render. In that case, ignore my last statement.</edit>
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
