Go to Post We'll defintely be working on both the balancing 2 wheel robot, the 6 legged robot, and the wood chassis 8 wheel drive robot ideas this fall. - MrForbes [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
  #16   Spotlight this post!
Unread 08-01-2017, 14:44
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: FRC 2017 Competition Field
You can create a new front view based on the current view but I think you are probably looking for something more dynamic. This solution would be a single, mostly static view.
Let me think about it some more for a better solution.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
  #17   Spotlight this post!
Unread 08-01-2017, 23:33
Eraani Ruiz Eraani Ruiz is offline
FRC #3158
Eraani Ruiz is an unknown quantity at this point
Question Re: FRC 2017 Competition Field
Hello,
My team and I tried to download the Inventor and the Fusion 360 but somehow cannot open it in neither of the programs, is there something else we need to do in order to open those files (apart of downloading the programs) or an explanation to why we cannot open them?
Thanks
  #18   Spotlight this post!
Unread 08-01-2017, 23:52
echin's Avatar
echin echin is offline
AKA: Eric Chin
FRC #3467 (Windham Windup)
Team Role: Leadership
echin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the rough
What version of Inventor/ Fusion are you using? Autodesk files are not backwards compatible (you can't open an Inventor 2017 file in Inventor 2016). If that's the issue, you could try the STEP file as others have suggested.
FRC 3467 Chief Technology Officer (Co-Captain)
FTC 10251 Design Mentor
  #19   Spotlight this post!
Unread 09-01-2017, 01:30
markmcgary's Avatar
markmcgary markmcgary is online now
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Thank you for making the Field CAD available. The ability to visualize this game from a drive team perspective has been quite shocking. I have not seen much discussion of the visibility challenges that the AIRSHIPs are introducing to this game. I think that it will be very difficult to cycle GEARs or even FUEL depending upon your PLAYER STATION because FIELD visibility appears to vary wildly. Am I missing something?
  #20   Spotlight this post!
Unread 09-01-2017, 01:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Originally Posted by Eraani Ruiz View Post
Hello,
Thanks
For Inventor, you might want to set your project file to the included one first, then open the assembly. Also, make sure you are running Inventor 2017. Otherwise, as mentioned, use the STEP files.
  #21   Spotlight this post!
Unread 10-01-2017, 10:15
amaniace amaniace is offline
FRC #0677
amaniace is an unknown quantity at this point
What scale did you use to make this? Is that explained in the video?
  #22   Spotlight this post!
Unread 10-01-2017, 13:07
The parts are actual size, so 1:1.
Phil Dollan
Autodesk Inc.
  #23   Spotlight this post!
Unread 10-01-2017, 18:31
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Team Role: Mechanical
Rookie Year: 2014
Levi Madden is on a distinguished road
The dimension for the baseline had been corrected in team update 1. It is NOT 9 ft 4 inches (previous manual statement). It is 7 ft 9 and 1/4 inches from the alliance wall (team update 1 statement).
  #24   Spotlight this post!
Unread 10-01-2017, 19:34
Nbot's Avatar
Nbot Nbot is offline
FRC #4488 (ShockWave)
Team Role: Electrical
Rookie Year: 2015
Nbot is an unknown quantity at this point
Props to Autodesk for making their CAD more accurate than the game manual.
  #25   Spotlight this post!
Unread 12-01-2017, 20:43
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Is the fuel modeled correctly in the KoP download? Ours is 4" diameter.
We corrected it by making the ball 2.5" diameter and the hole pattern spacing to 2.5" as well.
  #26   Spotlight this post!
Unread 12-01-2017, 20:56
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
The field I downloaded has the baseline at 9ft from the alliance wall, is there an updated version out there somewhere?
  #27   Spotlight this post!
Unread 15-01-2017, 13:50
Check out the field on the Autodesk website.
http://www.autodesk.com/education/co...t/all-products
Let me know if this works.
Phil Dollan
Autodesk Inc.
  #28   Spotlight this post!
Unread 15-01-2017, 17:11
Hadi379's Avatar
FRC #0379
Phil,
I think that link is incorrect
  #29   Spotlight this post!
Unread 16-01-2017, 02:18
Phil Dollan
Autodesk Inc.
  #30   Spotlight this post!
Unread 16-01-2017, 11:51
CoachDotKam CoachDotKam is offline
FRC #1189
CoachDotKam is on a distinguished road
We have some video of the field from driver stations that we captured through VR. https://www.youtube.com/watch?v=r3IwrBywC7g
https://www.youtube.com/channel/UCMm...7a8p-upznqTk_w
