| My servos lock up just thinking of you |
Fuel Seems Undercosted
Does anyone else feel that Fuel is under costed in this game?
You can put in 120 high efficiency or 360 low efficiency Fuel to get the same amount of points as one gear in teleop. (I will concede that there is one QP for Fuel that would be valuable) Plus, would the field be able to count 360 balls in 150 seconds (full match)? |
Re: Fuel Seems Undercosted
Don't ignore the 'pressure' associated with a ball, at 40 kPa you see a Ranking Point, win or lose.
Notice that the rotor has to be turning to get 40 points. So while that rate is true for the first gear, towards the end 120 fuel is equivalent in points to the 4 gears required for the last rotor.
The pilot is required to place 6 gears for the last rotor. They then have to do three rotations of the first gear, which might be harder than some people think.
Just because a task closely resembles the "main" task of old games, doesn't mean it's the "main" task of this one.
Also, fuel has an effectively infinite scoring potential, whereas gears are finite. True, the gears limit is relatively high and will take many alliances the full match or more to reach, but others will be able to finish them off with plenty of time to spare. In these matches, where both alliances do this, fuel will be the difference maker. Additionally, there's two very key differences between fuel and most recent shooting tasks: the ball is tiny compared to the robot, and storage is unlimited. Unlike recent games, and especially unlike last year, where you had to make every shot count, pure rate of fire is arguably more important than actual accuracy, and the size difference opens up some interesting possible ways to make this happen. Last edited by Joe G. : 07-01-2017 at 14:17. |
Can anyone find a rule on how much fuel one robot can carry? Please link a rule where you found the answer
There is no limit
Where did you find that? I'm telling my team this but I cant find it in the rules
#10
Also, I believe this was mentioned specifically in the Kickoff stream, I want to say in Blair's segment. |
#11
It was said during the live webcast, you can watch a VOD of that, it isn't in the rules because it would only need to mention it if there was a limit. There's is a theoretical limit due to the volume constraints on the robot but other than that there is none.
#12
Since the boiler takes about 2 seconds to process fuel, the following questions are:
What is the boiler's capacity? Are there separate counters for top and bottom? |
#13
I'd assume so since they are scored differently. |
#14
No, but how much overflow can the boiler handle (say if you shoot at >5 fuel/sec)?
#15
I think this depends on the geometry of the funnel. I can't find it in the field drawings, but it would be nice to see someone calculate the maximum possible number of fuel.
