Go to Post Dang. There goes the hint that was supposed to go out next week. Gotta start over now.. - dlavery [more]
Unread 07-01-2017, 13:00
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Plywood and 2x4 Cutting Diagrams for Field Elements
Hi all,
In the event you want to build all (or some) of the field elements using the FIRST supplied drawings, I have prepared a cutting diagram.
You can ungroup the individual sheets and rearrange the parts to build just what you need.
https://www.dropbox.com/s/yb7pwdcgyj...ayout.dwg?dl=0
Hope that helps.
Jason
Unread 07-01-2017, 15:40
Ubiquity Ubiquity is offline
FRC #5027
Ubiquity is an unknown quantity at this point
Re: Plywood and 2x4 Cutting Diagrams for Field Elements
I am missing the specs on the "spring?" for the lift - is there a guide to the hardware for the field elements anywhere? Thanks for the cutting diagrams.
Former mentor: 255(4y), 254(2y), 668(1y), 751(1y),5027
Current mentor 2854, 5905
Volunteer, Ref, Inspector, Judge, FTA
Nat. Champion 2000(255), Nat. Chairman's 2004(254), SVR Champion 2015(5027)
(Botball N. Champ 2001)
Unread 07-01-2017, 15:58
Clear7 Clear7 is offline
AKA: Nathan Noble
FRC #2594 (NASKCO Robotics)
Team Role: Electrical
Rookie Year: 2014
Clear7 is an unknown quantity at this point
OMG! Thank you so much. For the past 3 years my team has decided to build at least half the field so that we can practice. This is so helpful!!!
Thank you so much!
Unread 07-01-2017, 16:03
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
The spring is: https://www.mcmaster.com/#9664k68/=15oiof2 cut to 9".
Assembly instructions are here: https://firstfrc.blob.core.windows.n...amVersions.pdf
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 07-01-2017, 16:07
ItGuru55 ItGuru55 is offline
AKA: Bill Wrye
FRC #1311 (Kell Robotics)
Rookie Year: 2015
ItGuru55 is an unknown quantity at this point
Thank you so much for assembling this, it will help reduce waste a bunch!
Unread 07-01-2017, 16:15
Stappy Stappy is offline
FRC #5084
Stappy is an unknown quantity at this point
The Peg Lift peg size is missing also. No specs on it
FridgeBot Inc
Providing robotic appliances since 2014!
Unread 07-01-2017, 16:19
AKA: Kevin Dieterle
The peg lift peg is on page 9 of this document https://firstfrc.blob.core.windows.n...amVersions.pdf TE-17002-05
Please remember to refer to the official drawings for anything that may be missing or you have questions on.
Unread 08-01-2017, 01:27
AKA: Jason Brett
Thank you so much!
You're very welcome. Putting the components together today we noticed that I left one part off the diagram It was for the "human" loading station. Part #1, if I recall. I included one, but there should be two. Everything else worked out great!
Jason
Unread 08-01-2017, 02:35
Grogrey Grogrey is offline
AKA: Gregory Adelman
FRC #2990 (Hotwire Robotics)
Team Role: Mechanical
Rookie Year: 2013
Grogrey is an unknown quantity at this point
Originally Posted by Deetman View Post
Do you have a link to the barb piece that goes on the end of the spring?
Unread 08-01-2017, 10:48
RobotBill's Avatar
RobotBill RobotBill is offline
RobotBill
AKA: Bill Aucoin
RobotBill is an unknown quantity at this point
FWIW, we generated a master bill of materials to help with getting the raw materials procured for making the team field elements. No guarantees on its correctness, but it was helpful for us.
https://drive.google.com/open?id=0By...GYwdmtYS3pSNlE
Unread 08-01-2017, 12:03
AKA: Jason Brett
It should be in the FIRST drawings. Last page of the lift drawing, as I recall.
Jason
Unread 08-01-2017, 17:03
Gene K. Gene K. is offline
FRC #1701
Gene K. is an unknown quantity at this point
How do I use the layouts drawn in blue and red to determine the exact number of pieces of plywood required to build the field elements? It appears only the 3/4" plywood is identified in the blue drawing. Are the red drawings all 1/2" plywood?
Unread 08-01-2017, 17:28
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
If you compare the item numbers written in Jason's CAD file with the FIRST-provided 2017 Team Version Drawings, you should be able to figure it out.
Unread 08-01-2017, 18:30
AKA: Jason Brett
Correct. You'll note the layers are named for the material... Green is on the 2x4 layer, blue on the 3/4" layer and red is the 1/2" layer. If you check out the FIRST supplied drawings (see above post) then you'll get a full inventory of the parts. The FIRST drawings, however, don't give you the parts in a useful fashion for determining how much wood you need or how to slice it.
I recommend numbering each part as you cut it. Refer back to FIRST's drawings for details on the parts with holes or angle cuts. Note that the hole cut out of the top of the boiler is re-used to make the touch bracket at the top of the rope.
It took two of us about five hours in a well-equipped wood shop to slice up all the parts, and a couple hours for teams of students to assemble them.
Again, if you only want some of the elements, you can ungroup the various sheets and rearrange the pieces to get only those you want.
I also expect that you'll be able to recreate functionally identical elements using alternate methods...
Jason
