Go to Post When your driver is the "world record holder in Mario Cart" you know it's going to be exciting for the students and stressful for the pit crew. :ahh: - lovelj [more]
Unread 07-01-2017, 14:40
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
New size/bumper rules that every team should know
Two subtle changes to the rules that have huge impact, and the potential to really hurt some teams if they're not careful.
<R03>Maximum ROBOT size, including BUMPERS and all extensions, must be constrained to one of
two volumes:
A. 36 in. by 40 in. by 24 in. tall (~91 cm by 101 cm by 60 cm tall).
B. 30 in. by 32 in. by 36 in. tall (~76 cm by 81 cm by 91 cm tall).
The ROBOT must remain constrained to the maximum inspected volume at all times during the
MATCH (i.e. A ROBOT may not switch between volume A and volume B without being reinspected).
The first big change: Bumpers are now included in the robot size limit. This means that your physical robot must take into account the ~3.25" on each side a bumper will take up, but also take into account the fact that bumpers are soft, squishy, and tend to shift, and are probably not as dimensionally reliable as what we're used to using as a frame perimeter defining part. Leave extra room, and don't forget the bumper size entirely.
However, bumpers must still be removed for inspection so that the robot can be weighed. So don't make them 100% integral to the frame just yet.
The second, more subtle change. For the first time since 2009, the robot is limited to the same size in its starting configuration as during the rest of the match. However, the rule is not the same as the 2009 rule. 2009 was frame perimeter based, and banned any extension over the starting perimeter. If you chose to be small, you were stuck small.
This year, however, it's a fixed maximum size. If you want to reach over the bumper to expand your intake, grab a rope, or anything else, you can do this, but only if your base/frame perimeter is smaller than the maximum size. Say, for example, you choose the 36"x40"x24" size. A drive base/bumper assembly built at 36"x40" cannot have a drop-down intake of any sort, and will be constrained to a bumper-cutout intake with 6" on each side (another change, down from 8"). However, if the team instead builds their bot 36"x30", they have a full 10 inches outside of the bumper to extend and build anything they want. This mechanism must still retract due to <R02> for the start of the match.
Plan your drive base carefully. Bigger is not necessarily better, and may lock you into a design and prevent you from duplicating something cool you see at a first event.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 07-01-2017, 14:53
aguzauckas aguzauckas is offline
FRC #4557 (The FullMetalFalcons)
Rookie Year: 2015
aguzauckas is an unknown quantity at this point
Re: New size/bumper rules that every team should know
Whether or not the bumpers are included in the perimeter is contrasted in R01 and R03. Has FIRST said that the bumpers are included in the perimeter? If so, please post the link.
Unread 07-01-2017, 14:58
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
<R01> and <R03> do not conflict. <R01> states that the robot must have a FRAME PERIMETER, meeting the fixed, non-actuating, etc. requirements we all know and love. The FRAME PERIMETER is referenced in <G09>, which deals with interactions between robots, <R02>, which states that everything except the bumpers must start (but not necessarily end) the match inside the frame perimeter, and repeatedly throughout the bumper rules, which deal with how the bumpers must attach to and interact with the FRAME PERIMETER. However, <R03>, which deals with the actual size limit of the robot, clearly includes the bumpers in this, and does not reference the FRAME PERIMETER in any way.
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
I believe the frame perimeter rules are there to help define the bumper rules (I.E if you have a V robot frame you don't need to put bumpers inside the V) and to define the starting configuration. There are no frame perimeter limits only volume limits.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 07-01-2017, 15:06
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Team Role: Coach
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
This is immediately what I thought of as well. The last 4 seasons have had very different bumper and frame perimeter rules - FIRST and the GDC should highlight this subtle (but major) change as much as they can over the next 10 days or so.
Like Aquidneck Island Robotics on Facebook!
Unread 07-01-2017, 15:29
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Team Role: Mechanical
Rookie Year: 2015
NShep98 is on a distinguished road
R22. ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME
PERIMETER. For adequate protection, at least 6 in. (~16 cm) of BUMPER must be placed on
each side of each outside corner (see Figure 8-1). If a FRAME PERIMETER side is shorter than
6 in. (~16 cm)
This is reduced from 2016's 8 inches.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 07-01-2017, 16:11
Harshizzle's Avatar
Harshizzle Harshizzle is online now
AKA: Harshal Singh
FRC #4828 (RoboEagles)
Rookie Year: 2012
Harshizzle is on a distinguished road
This seems to defeat the purpose of bumpers, at least how they've been used the past few years, doesn't it?
They used to guarantee about 6 inches of distance between "internal components" of robots. With this game, everything will always be inside the frame perimeter, but the grace distance that the bumpers used to provide doesn't exist. Teams will have to be careful to either build robustly, or be well inside the bumpers.
Bumpers may or not actually provide any protection.
This makes the real volume less than the stated volume.
FRC Team 4828
2013-2016
Think Big.
Unread 07-01-2017, 16:17
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
I'm not sure I see your point...
At the start of the match all parts of the robot except the bumpers must be within the frame perimeter (which does not include the bumpers) as typical in FRC. The grace distance is still there. The only things that are vulnerable are frame perimeter extensions that deploy after the match starts as usual.
Unread 07-01-2017, 16:45
Harshizzle's Avatar
AKA: Harshal Singh
Rookie Year: 2012
Oh whoops, I feel silly, I misread the rules on it.
FRC Team 4828
2013-2016
Think Big.
Unread 07-01-2017, 17:57
BBaltrusch BBaltrusch is offline
FRC #4818 (The Herd)
Rookie Year: 2013
BBaltrusch is an unknown quantity at this point
I'm afraid there's going to be several teams unable to compete at their event because they show up with bumpers outside the sizing box and have no way of cutting 5-6" both directions. Glad I'm not the LRI that has to tell them that.
Unread 07-01-2017, 18:02
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
Not sure if this is the right place but would these bumpers be legal?
http://imgur.com/aK9ofzy
The gap is 13 inches but there will be a beam above the bumpers connecting the two sides so that the frame is technically all closed.
edit the two shorter sides are both 6 inches.
This is safe... right?
Unread 07-01-2017, 18:09
NShep98's Avatar
Rookie Year: 2015
That would not be legal because the frame perimeter is measured as a convex polygon wrapping around the robot, so the two pieces pointing inward would not be considered bumpers.
FLL 2011, 2013
Unread 07-01-2017, 18:10
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Before I answer...
What is your Frame Perimeter? Read R01, particularly the blue box. Now read R22, including the blue box, and R29G. I'll explain in the spoiler, but I'd like you to read those rules first.
Spoiler for The Answer:
Your frame perimeter is a convex polygon formed by the outside corners of your robot, per R01. R22 says that you have to have 6" of bumper on each side of each corner of the frame perimeter, and R29G says that bumpers have to be mounted to the frame perimeter. The portion of the pictured bumpers inside the points are not protecting 6" of frame perimeter, and they aren't mounted to it. The robot portrayed has a rectangular frame perimeter, and the bumpers aren't going to be legal like that.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-01-2017, 18:51
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
R23. BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between the floor and a virtual horizontal plane 7 in. (~17 cm) above the floor in reference to the ROBOT standing normally on a flat floor.
New this year,the top of the bumpers is 7" this year (think bumpers end up 5.5-6.5" tall with fabric. My memory says last year the bumper zone was 5-12" off the ground.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
  #15   Spotlight this post!
Unread 07-01-2017, 23:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Yes, last year's was the highest bumper zone since our rookie year (2012), and this year is the lowest since then. Fortunately, there are no scoring platforms or defenses or anything but flat carpet to drive over.
