#31
Re: Any idea for how many balls the boilers can hold?
It would be nice if FIRST would make a few more field videos showing from the field side and behind the wall what happens if they dump 50 ball into the high and low goal slots.
Since I know Q&A isn't the place to resolve this - does anyone know where such a request could be directed? Thanks! -matto- |
#33
I'd echo this and add that the amount of Fuel that can fit in the Return bin is more important (and less) than the amount that can fit in the Boiler.
#34
#35
Theoretically the answer is an unlimited amount, since the game pieces can stack up on itself and not count toward the robot height (and assuming physics didnt exist
#36
I disagree - the q&a is a good official vector for this. too bad it only opens in a few days, after most teams would really like to have finalized their strategy. |
#37
Hmm, maybe if somebody wrote a program that could recognize and delete all of those questions before the GDC had to see them, maybe they'd be willing to open up the Q&A earlier. |
#38
The hexagonal plate is a part of the steam tank. If you look at the model of the steam tank it's in there. A duplicate somehow was mistakenly placed in one of boiler assemblies.
#40
P.34 says "The capacity of the Low Efficiency GOAL is seventy (70) FUEL. The capacity of the High Efficiency GOAL is one-hundred and fifty (150) FUEL. FUEL that exceeds GOAL capacities will fall back on to the FIELD."
Does it means that in any point of time these are the max fuels the boiler can hold? |
#41
According to one of our coaches this was in the first update:
The capacity of the Low Efficiency GOAL is seventy (70) FUEL. The capacity of the High Efficiency GOAL is one-hundred and fifty (150) FUEL. FUEL that exceeds GOAL capacities will fall back on to the FIELD. |
#43
Essentially dump, cram and shake in as many balls as you can into the unpowered boiler then count the balls. To me it seems unlikely that this process would yield such an even number of balls, so I expect this is a theoretical calculation instead of a physical measurement. My guess is that they rounded down slightly since they put these explicit values in the manual. -matto- Last edited by aldaeron : 11-01-2017 at 10:43. Reason: Spelling |
#44
I wonder if the 150 high fuel capacity includes fuel inside the pipe. The pipe itself could probably hold around 30-40 balls.
#45
Efficiency GOAL is one-hundred and fifty (150) FUEL. FUEL that exceeds GOAL capacities will fall back on to the FIELD. coming from team update 1. |
