Re: Auto Rotor Point Total?
I think we'll see 120 pt. rotor scores in auto from some playoff alliances. Likely with each robot hanging a gear.
Re: Scoring of rotors
Two similar threads merged, resulting in somewhat out of order posts.
There are stack lights for the first three rotors that are meant to indicate if each rotor was engaged in auton. I assume (I know, bad idea) FIRST would not put a stack light on the second (or third) rotor if they did not expect it to be spinning at the end of autonomous at least once.
As far as our team currently understands it:
Rotors are scored if they are turning at T=0 of a period (per the scoring chart on page 42 of the manual). They are not scored when they start turning. An indicator is on the first two rotors (as per page 23 of the manual) because they are the only two which can possibly be powered during autonomous (maximum of 3 gears can be lifted during auto). There is however, no discussion of that indicator causing such a rotor to not be scored at the T=0 of the tele-op period. In our thoughts (but we wait for some official decision), the score for such a rotor is as follows: Autonomous ends (T = 0) -> 60 points per rotor spinning Tele-op ends (T = 0) -> 40 points per rotor spinning. Each rotor started in auto is effectively worth 100 points by the end of the match. Making the maximum points for engaging rotors 200 (auto, 2 rotors) + 160 (tele, 4 rotors) + 100 (playoffs bonus) or 1 RP (quals bonus), for 460 points, or 360 points and an RP. Note, the logistics of powering the 2nd rotor during autonomous: not only must you deliver all 3 gears to their lifts, the 2 pilots must then lift the 3 gears and place them properly (this means one pilot must lift 2 gears within 15 seconds, safely) then make 3 rotations of the second rotor. This process must be complete within 15 seconds, as the rotor must be spinning at T=0 of auto. [b]TL : DR[\B] - as of current rules, 60 points for auto + 40 points per tele-op, even if it started spinning during auto = 100 points. Can get 2 rotors during auto, but very difficult in the time limit. |
as far as quickly and safely lifting three gears, I also suspect that an update will be made requiring the pilot to drop the lift back down before placing the gear. this is slower, but is a tripping hazard. otherwise the faster thing to do is not reset the lift until the beginning of teleop. |
From today's Team Update 1:
That kinda dulls our autonomous plans then. I mean, 60 points is 60 points, but it would've been nice to do something a little cooler. Maybe we will have to add a ball dumping into our auto or something to make it a little more interesting...
a single robot can score 100pts+1RP solo in auto. this will happen at least once.
#10
Is there some magic happening that I don't see? ![]() |
#11
The closest I can find: Quote:
#14
HUMAN PLAYER practice will be a must. Perhaps once people get a AIRSHIP model completed with LIFTs, they will share on youtube the possibility of the 380 point teleop score for more buy in.
Is it safe to say that the Robot can not push the lift up? I see a statement that reflects that it is to be pulled up by the player. But Robot interactions do not exclude pushing field elements. I see this as a potential safety issue as a GEAR could be moving up without the PILOT's direct manipulation, however students may think it saves the pilot time by having the robot lift up the gear for them. |
#15
I tried looking through the field assembly...
It it about a 2.5 ft cable pull to get the gear from the bottom of the LIFT to the PORT? |
